Low Pressure Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by silvertaco408, Dec 31, 2007.
  1. Dec 31, 2007 at 5:08 PM
    silvertaco408
    silvertaco408 [OP] Well-Known Member
    San Diego, CA
    17 double cab long bed 4x4 trd off road
    Pioneer Avic Z2 navigation with ipod and bluetooth, K&N 77 Series intake, DT Headers, Flowmaster 50 exhaust, All Weather Mats, Fog Light Mod, Debadged, 20% tint all around, custom blue dome, maps, steering wheel, shifter lights, and cluster, Midland CB with PA, XD Series Revolvers wrapped in BFG AT's, black mesh grillcraft grill
    My low tire pressure light came on and I can't seem to get to turn off. Ive tried that reset button...nothing. Ive also ran the tire pressure up higher than normal trying to reset it and its still on. I have the stock tires. Any suggestions and has this happened to anyone else?
  2. Dec 31, 2007 at 5:11 PM
    dirthawker1313
    dirthawker1313 Well-Known Member
    have you checked the air pressure in your spare tire? it also has the TPMS. and if that tire is low you wont get it to go off. IMO
  3. Dec 31, 2007 at 5:14 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    spare tire usually gets everyone on the tpms
  4. Dec 31, 2007 at 5:22 PM
    silvertaco408
    San Diego, CA
    ya i checked the spare and the pressure is right where it should be.
  5. Dec 31, 2007 at 5:23 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    A friend who has a newer Toyota car said something about the TPMS comparing the pressure between the tires..example if you got one low tire then lowered the remaining tires to match then the light would go off..does the system work that way???
  6. Dec 31, 2007 at 5:24 PM
    The_Hodge
    SC
    that sport should be running 29psi at all 4 corners...besides that, i would say to talk to the dealer if they're all at 29psi and its still on
  7. Dec 31, 2007 at 5:25 PM
    The_Hodge
    SC
    well...29 psi as long as ur still running stocks
  8. Dec 31, 2007 at 5:26 PM
    silvertaco408
    San Diego, CA
    Im not sure because I raised all of the tires so that they are the same and its still on.
  9. Dec 31, 2007 at 5:37 PM
    The_Hodge
    SC
    try resetting them all back to 29psi and reset the tpms and see whats going on...all 4 and spare
  10. Dec 31, 2007 at 7:17 PM
    silvertaco408
    San Diego, CA
    Still didnt work. I think I should just take it to the dealer. It is all under warrarnty anyways.
  11. Dec 31, 2007 at 7:22 PM
    The_Hodge
    SC
    yeah...if everything is sitting at factory specs and all, i'd definately take it in and see whats up
  12. Dec 31, 2007 at 7:28 PM
    silvertaco408
    San Diego, CA
    yep. hey was it easy to put the bed cargo lights in.
  13. Dec 31, 2007 at 8:28 PM
    The_Hodge
    SC
    all i did was wire in a set of fog lights in the bed pockets...others have used underbody neons and such...not hard at all
