Low pulsing hum felt in pedals and steering wheel in 2015 DCSB SR5 4x4.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ldickersonc, Aug 3, 2022.
  1. Aug 3, 2022 at 5:53 PM
    ldickersonc
    ldickersonc [OP] Member
    I mostly feel this at low speeds, 25mph or lower. I cannot tell if it goes away above that or I am just unable to hear it over the road noise. Its about a 1 second pulse of a hum followed by about 1 second of nothing. I have jacked up the front and shaken the shit out of the wheels to check for wheel bearings, no play. Changed the front diff fluid and greased the driveshaft, no change. Recently there has been a grease leak from the drivers side CV boot at the wheel. Truck drives smooth and quiet on the highway. I have to drive it from New York to California next month, so I'm trying to get it in tip-top shape. 160,000 miles, no towing or off-roading, 4wd used primarily in winter up here on snowy and icy roads.
  2. Aug 3, 2022 at 6:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’ve never been able to get any play out of a failing wheel bearing in these trucks.
    You have to spin the wheel and feel it at knuckle or tie rod. If it has play is it WORN FLAT OUT.
    In my experience these bearing go through vibration and noise stages as the wear progresses. Easiest give away is if the noise changes when turning.
    If you want to see if it’s the needle bearing in the front. See if noise goes away in 4WD.
    And don’t think a bad rear wheel bearing can’t mimic a front. It can sometimes.
    Key-Rei and Dm93 like this.
  3. Aug 3, 2022 at 6:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Does it happen while turning corners? Might be that Trac control issue that gets fixed with a recalibration
    Dm93 likes this.
  4. Aug 3, 2022 at 6:37 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Should see a Traction Light flashing when it's happening if that's the case but good point.
  5. Aug 3, 2022 at 6:38 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sometimes people don't look down ;)
    Dm93[QUOTED] likes this.
  6. Aug 3, 2022 at 6:41 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Or they look down, see the christmas tree, and ignore it until it just won't go anymore:rofl:
    b_r_o[QUOTED] likes this.
  7. Aug 3, 2022 at 6:44 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I had a pulse exactly as you described that I could feel in my pedal, I felt it at 35-55 but I also have 34" tires so the harmonics would be different from yours.
    My educated guess is it's your wheel bearings as replacing mine fixed it.
    I recommend @05Taco4x4 's "press service".
    05Taco4x4 and TnShooter like this.
  8. Aug 3, 2022 at 6:56 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    I have the same pulsing vibe felt in the pedals and through the floor at 35-40 as well as 65-70. I have 44k. Also happens (worse) when turning when slower (25-30). Haven't thrown any parts at it but haven't been able to figure out what it could be.
  9. Aug 3, 2022 at 6:58 PM
    ldickersonc
    It does indeed happen while turning
  10. Aug 3, 2022 at 7:01 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Next time you feel it, look down and see if the Trac light is flashing
  11. Aug 3, 2022 at 7:05 PM
    ldickersonc
    Never got a light, but I will pay attention to it
  12. Aug 3, 2022 at 7:11 PM
    Waasheem
    Waasheem
    2007 xrunner
    Or only look down at a phone til they wreck.
  13. Aug 3, 2022 at 7:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You could try the recalibration and see if it helps. There's a link around here somewhere
    I've always done it with a scan tool but pretty sure there's another way
  14. Aug 3, 2022 at 7:16 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  15. Aug 5, 2022 at 9:34 AM
    ldickersonc
    Some other threads on the forum led me to diagnose the needle bearing (and you guys in this thread as well, thank you). The maintenance doesn't look bad at all to fix. Question now, should I do this before the cross country drive, or is it safe to leave for when I arrive in California? What can go wrong?
  16. Aug 5, 2022 at 11:16 AM
    TnShooter
    Deogee
    STOCK
    I drove on mine for over a year.
    I am not saying that’s what you should do, but I did. Not necessarily on purpose.
    Procrastination and gathering tools to do it was the biggest reason.
  17. Aug 5, 2022 at 12:43 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Are you stock height? I have the 3rd gen suspension so I guess I'm +1 in the front but had felt it before I did that. Kind of always put the needle bearing to the side because of the fact that I'm not lifted...
  18. Aug 6, 2022 at 10:53 AM
    ldickersonc
    I am not lifted, truck is stock height. The most aggressive thing I have done is put Bilstein 4600's on it....
    AJKlug1[QUOTED] likes this.
  19. Aug 6, 2022 at 12:36 PM
    TnShooter
    Deogee
    STOCK
    My truck is stock. My needle bearing want bad. It’s not common, but it can happen to stock trucks.
    Some will probably say it was because I didn’t change the diff fluid soon enough.
    Who knows? I know plenty of guys that have never changed their diff fluid and their needle bearing is fine.
  20. Aug 6, 2022 at 1:24 PM
    ldickersonc
    The truck has 160k on it, so things are bound to start going bad. Its been pretty bulletproof, so I can't complain. Its fun to turn a wrench every once in a while....
