Low Range Off Road 3/1 lift/level kit anyone?
Discussion in 'Suspension' started by VanceLee, Jul 15, 2016.
  1. Feb 19, 2018 at 9:11 AM
    #121
    thunderhorn25
    thunderhorn25 New Member
    Looks good! Trying to decide what to do on my 2017 taco sport...do a lot of hunting and the forest roads here in AZ are usually super Rocky and rough. Only planning on going up one tire size though.
  2. Jun 27, 2018 at 9:23 AM
    #122
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    I got my 2017 OR DCSB from the dealer with the pro comp lift, 20" pro comp wheels (-12 offset) and 275/60r20 pro comp AT sport tires...the rims were excessive for both my needs and taste, but considering they dropped the price just over $4K to price match an '18 OR DCLB I had local dealers work up pricing. My off road ventures include modest trail riding for camping, backpacking and hunting, as well as some marsh and sand use.
    I'll run the wheel/tire combo until new tires are needed, likely try and move the 20" rims (they're nice, but excessive)then move down to a 16" rim and see about running 285/75r16...both for more sidewall, but also because tires on 20s are pricey!
  3. Aug 3, 2018 at 4:29 PM
    #123
    Gettin Lost
    Gettin Lost Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    Just got this kit installed a few days ago. Has alignment same day. Then drove over 300 miles, round trip combined, to pick up a backflip g2 bed cover... No vibrations, no pulling left or right, ride seems pretty much the same... Stock ucas.
    Though I do notice a decrease in mpg in speeds over 70. Down to 16-17 now. But I don't drive that fast too often so I can live with it.
    BEFORE...
    AFTER...
    My question is.... are spacers required if I go up to 285/75/16 tire size and keep these rims? What about 255/85/16?
    I'd really rather the 285 because there's more options. I could stick with wildpeak tires, and not have to spend over 700 bucks...
    But I'd rather not use spacers honestly.
  4. Aug 3, 2018 at 4:31 PM
    #124
    Gettin Lost
    Florida
    2021 TRDOR
    Current tire size is 265 75 16
  5. Aug 4, 2018 at 7:32 PM
    #125
    Yodason
    Yodason Well-Known Member
    If the vibration goes away when you put it in 4 Hi, it’s the driver’s side needle bearing. Installed the LRT 3 to 1 leveling kit, took about 3 weeks
    and I started hearing a rub, rub, rub sound at 35 - 45 mph. 4 hi went away. Ordered the ECGS bushing and puller. Removed the needle bearing and put the new bushing in...no more grinding. LRT should include the bushing and puller in their kit. Common problem in the Tacoma and FJ Cruiser. I think it’s not “if” it’s when.
  6. Oct 17, 2018 at 7:44 PM
    #126
    DrewsWSO
    DrewsWSO New Member
    2017 TRD Sport
    LRT 3/1 Leveling kit
    I recently installed this kit on my 2017 TRD Sport, and the driver side front fender is a 1/2 inch lower than the passenger side. Th driver side rear is a 1/4 lower which I expected due to the lean, but was surprised to see such a split on the front end. We installed everything per the instructions, and I had the alignment done after installing with no change. Can anyone think of what is causing the difference?
  7. Oct 18, 2018 at 6:50 AM
    #127
    Gfunk123
    Gfunk123 Well-Known Member
    '13 limited taco
    3” level kit front, Dakar HD w/ Billy B110’s, 1.25” spidertrax, 265/70r18 Falken Wildpeaks AT3W
    I installed this kit in the spring and had to replace needle bearing not LROs fault. Was able to use factory UCAs. Kit appears to be great quality. For me it gave my truck a slight bro lean which I don’t like at all. Back settled to almost and 1” lower than front. I also got some vibes but all trucks are different.
    I also towed my popup camper with this and it was headlights to the sky due to the crap leaf springs.
    Just switched out leafs the other week to HD Dakar pack and think truck looks much better. Plan on swapping out front spacers to some OME 886 next spring.
    Wish I had gone Dakar and 886 first go round. I have some acceleration vibes w the Dakars but need to mess w shims to get it right.
  8. Mar 4, 2019 at 9:51 PM
    #128
    Roddy13
    Roddy13 Well-Known Member
    A lot of these look a bit nose high.
  9. Mar 30, 2019 at 3:22 AM
    #129
    burddog
    burddog Active Member
    Ephrata, PA
    2015 prerunner
    American Outlaw Hollywood 17x8.5 -10 offset Bilsein 5100 all around Low Range 1" rear Blocks Hankook Dynapro atm 265/70/17 Shaved badges A little rattle can green on the front. Gator soft bed cover
    I'm seeing the same thing.. nose high.
    I was dead set against spacer kits from reading all the cons. But I was just at my local Toyota dealer and they use Rough Country spacer kits. Warranty included when they put them on. Said they've done dozens of them with no complaints and maintain factory ride. I think bump stop spacers are the key to these so you dont crush your shocks.
    So I'm confused. I was sold on Bilstein 5100s, but now... ??
  10. Sep 13, 2019 at 11:25 AM
    #130
    buzbee87
    buzbee87 New Member
    Billy
    2019 Cement Tacoma TRD OR
    LRT 3/1 level, Spidertrax 1.25 wheel spacers
    Just installed the LRT 3/1 kit and couldn’t be happier. It’s the exact stance I was looking for...install took 2 hours (lift and air tools)
    tacofish likes this.
  11. Oct 7, 2019 at 8:07 PM
    #131
    VanceLee
    VanceLee [OP] Well-Known Member
    2016 Toyota Tacoma TRD Sport Blazing Blue Pearl
    Put new wheels on with a better outset. TRD of course. Got a great deal on them new. Still running the same low range off-road 3/1 lift and level. No complaints. 33k miles. New grille too. You can see the new wheels push the tires out at least to the edges of the fenders if not a little further. Added a sweet front cam to her too. She looks great in my opinion. IMG_20190425_175334~01.jpg IMG_20190317_181842.jpg IMG_20190317_181824.jpg IMG_20190317_153858.jpg
    vpcustoms and Tmaloy like this.
  12. Mar 21, 2020 at 6:53 PM
    #132
    Kirbstomp1287
    Kirbstomp1287 @MilSpecTaco
    17’ Inferno SR5 V6 DCSB XP
    I know this is an old thread but did any of your put longer shocks in the back to make up for the height of the blocks?
    Thanks for any help!
  13. Mar 21, 2020 at 8:45 PM
    #133
    VanceLee
    I didn't change anything about the shocks on mine. Fwiw.
