Low Range Off-Road's New Bumps Stop Rear U-Bolt Flip Kit
Discussion in 'Suspension' started by Low Range Off-Road, Mar 16, 2016.
  1. Mar 16, 2016 at 2:56 PM
    Low Range Off-Road
    Low Range Off-Road [OP] Well-Known Member
    Toyota Rear U-Bolt Flip Kit with Sumo Springs - 5/8" U-Bolts by Low Range Off-Road (TSP-BS-SSF-KIT)
    If you are having a hard time deciding on where to mount Bump Stops on your Toyota, look no further.
    This kit is a great budget Bump Stop solution as well as a U-bolt Flip Kit. We also provide the largest U-Bolts on the market for your Toyota.
    Kit comes with 2 U-bolt Spring Plates that fit SuperSprings "Sumo Springs".
    SumoSprings enable progressive load engagement, restrict body roll and enhance overall driver control. More than just a bump stop, this variable rate spring eliminates the unforgiving, banging effect produced by similar frame-mounted products.
    • Airless
    • Leak & rupture proof
    • Compression of 80% with full memory rebound
    • Manufactured from high grade microcellular urethane.
    • Adjustment free
    • Maintenance free
    • Built tough in the USA
    • Fit it and forget it!
    SumoSpring Dimensions
    • 3.5" Diameter
    • 4.0" Tall
    Includes 4 5/8 U-bolts, 8 High Nuts and 8 Hard U-bolt Washers.
    Fits:
    1979-1995 Toyota Pickups and 1985-1989 4Runners (U-bolt Flip) (Must Remount Lower Shock Mounts in Rear)
    1996-2004 Toyota Tacoma's, (U-bolt Flip) REAR ONLY (Must Remount Lower Shock Mounts)
    2005-2016 Toyota Tacoma REAR ONLY (U-bolt Flip) This kit is specifically for the rear 2005-2016 Tacoma
    https://www.youtube.com/watch?v=H2C0mF3D_V4
  2. Oct 26, 2021 at 9:58 AM
    dpf88101
    dpf88101 Well-Known Member
    Are these still available ?
