Low Range Off-Road's New Bumps Stop Rear U-Bolt Flip Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Low Range Off-Road, Mar 16, 2016.
  1. Mar 16, 2016 at 4:29 PM
    Low Range Off-Road
    Low Range Off-Road [OP] Well-Known Member
    Toyota Rear U-Bolt Flip Kit with Sumo Springs - 5/8" U-Bolts by Low Range Off-Road (TSP-BS-SSF-KIT)
    If you are having a hard time deciding on where to mount Bump Stops on your Toyota, look no further.
    This kit is a great budget Bump Stop solution as well as a U-bolt Flip Kit. We also provide the largest U-Bolts on the market for your Toyota.
    Kit comes with 2 U-bolt Spring Plates that fit SuperSprings "Sumo Springs".
    SumoSprings enable progressive load engagement, restrict body roll and enhance overall driver control. More than just a bump stop, this variable rate spring eliminates the unforgiving, banging effect produced by similar frame-mounted products.
    • Airless
    • Leak & rupture proof
    • Compression of 80% with full memory rebound
    • Manufactured from high grade microcellular urethane.
    • Adjustment free
    • Maintenance free
    • Built tough in the USA
    • Fit it and forget it!
    SumoSpring Dimensions
    • 3.5" Diameter
    • 4.0" Tall
    Includes 4 5/8 U-bolts, 8 High Nuts and 8 Hard U-bolt Washers.
    Fits:
    1979-1995 Toyota Pickups and 1985-1989 4Runners (U-bolt Flip) (Must Remount Lower Shock Mounts in Rear)
    1996-2004 Toyota Tacoma's, (U-bolt Flip) REAR ONLY (Must Remount Lower Shock Mounts)
    2005-2016 Toyota Tacoma REAR ONLY (U-bolt Flip) This kit is specifically for the rear 2005-2016 Tacoma
    https://www.youtube.com/watch?v=H2C0mF3D_V4
    seoulja99, ajohnson, Pirhett and 3 others like this.
  2. Mar 16, 2016 at 6:23 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Pricing?
  3. Mar 16, 2016 at 8:18 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
  4. Mar 25, 2016 at 1:43 PM
    TNT4X4
    TNT4X4 Well-Known Member
    CENTRAL NEW JERSEY
    2006 Tacoma
    285/75R17 on methods, Icon RR front with UCA, dakars with fox 2.0's out back. CBI Dakar Hybrid with homemade 1/4" skids. 4.56's with ARB.
    Any installed pictures?
  5. Mar 28, 2016 at 8:16 AM
    Low Range Off-Road
    We tested them out on a Employee's 2015 Tacoma for 6 months and didn't snap one photo. Very dumb on our part. :facepalm:But we will have an instructional Video in the future and we will show the advantages and a Go-Pro of the bump stop in action.
    PvilleJohn likes this.
  6. Mar 28, 2016 at 8:19 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    much like :thumbsup: subd
  7. Mar 28, 2016 at 8:35 AM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
  8. Mar 28, 2016 at 8:38 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Just as dumb as not giving us the PRICING? It's not on the website, so how much is it?
  9. Mar 28, 2016 at 10:06 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    nastyneight likes this.
  10. Mar 28, 2016 at 10:15 AM
    gottaToy
    JJ
    1985 Moped
  11. Mar 28, 2016 at 10:27 AM
    Low Range Off-Road
    We had this listed on our site when we posted this. We don't list price because of price changes that may occur in the long time future. Up or Down. Our Website always has the most current price's.
    I didn't link our website till we are approved to be an official vendor.
    T4RFTMFW likes this.
  12. Mar 28, 2016 at 11:33 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Company's aren't usually as addicted as we are and don't post 24/7
  13. Mar 28, 2016 at 11:44 AM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    As of today they are 359.99 USD. Like OP says, that can go up or down. You're welcome.
  14. Mar 28, 2016 at 1:00 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    360 bucks for urathane foam bumpstops and u bolt flip... good lord.
    Toytec ubolt flip kit is 63 bucks. Wheelers bump stops are 55.
    Full timbren ubolt flip kit with big bump stops.... 214 I mean shit.... at 360 bucks.... 40 bucks more and you can get a pair of 4inch travel air bumps that will be a SHIT TON better than some foam bumpstops.
  15. Mar 28, 2016 at 1:05 PM
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    Lol way to support the vendors.
  16. Mar 28, 2016 at 1:40 PM
    Low Range Off-Road
    We would like to say that this kit is Superior to all those kits. This Bump Stop has a way better ride quality than the Timbren. We have had many customers complain about how harsh and ruff the ride is with the Timbren's. The energy suspension Bump Stops are even harsher than the Timbren's and we have seen them fail many times. I alone have torn the polyurethane off the metal plate just ridding down a dirt road.
    This Top Plate is also made for future change to run Air Bumps as well. We utilize a 5/8" U-bolt which is much larger than what is available out there.
    A full Air Bump Kit with Brackets to install will run you over $650.00.
    We also offer free shipping on this Product.
  17. May 18, 2016 at 8:50 AM
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    Does using this flip kit with the Sumo's add height beyond just installing Sumo's without the flip kit? I'd like to flip the U-bolts but do not want to increase the height unloaded.
  18. May 18, 2016 at 10:08 AM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Bump stops and U-bolt flips don't add ride height.
    scottalot likes this.
  19. May 18, 2016 at 10:18 AM
    Mike O
    Thank you for the quick response. Some Sumo users are reporting 1/2 to 3/4" rise without the flip. I was hoping the bracket on the flip didn't and any more.
  20. May 18, 2016 at 10:20 AM
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    1st Gen Tundras?
