Low Rear Diff fluid symptoms?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lordviews, Dec 26, 2022.
  1. Dec 26, 2022 at 7:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You want to know what’s weird?
    Valvoline 75w-90 is synthetic based.
    Yet 80w-90 is NOT synthetic based.
    There has been numerous reports of synthetic base gear oil causing chatter in the mechanical LSD trucks.
    My vote is, use 80w-90 and run an LSD additive.
    Will it hurt it?
    Nope, not at all.
    Go read your owners manual, it never calls for 75w-90 in the rear differential.
    It says, 90w, 80w or 80w-90.
    Leomania and b_r_o like this.
  2. Dec 27, 2022 at 9:11 AM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
  3. Dec 27, 2022 at 9:48 AM
    TnShooter
    Deogee
    STOCK
    Friction modifiers won’t hurt an open differential. They won’t help either.
    But if you add it to all the fluid, you can never make the mistake of not using it if need.
    I think the dealership does it as a safety measure.
  4. Dec 27, 2022 at 11:32 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    To emphasize the point, only mechanical LSD units require the LSD modifiers. Mechanical LSD’s in second gen Tacomas were installed in certain 05-08 models. It came standard on Sport models. I don't recall if it was an option on non-Sport models. I am curious, do rear lock diffs require the modifiers?
    TnShooter likes this.
  5. Dec 27, 2022 at 11:58 AM
    TnShooter
    Deogee
    STOCK
    No, the locker does not require modifiers.
    It’s fully open until locked. And it’s physically locked. Modifiers have no bearing on the locking system.
    Chuy[QUOTED] likes this.
  6. Dec 27, 2022 at 2:43 PM
    lordviews
    lordviews [OP] Well-Known Member
    07 TRD Sport
    Just purchased some today. Do you think I can just add it to what I just put in? I just replaced it not too long ago and really don’t want to drain it again and buy it all over again if I don’t have to
  7. Dec 27, 2022 at 3:00 PM
    asuchemist
    NONE
    Yes, you should be able to add it in. You shouldn’t have to drain it.
    You might have to suck a little diff fluid out if you filled it correctly.
  8. Dec 27, 2022 at 4:09 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Once you add the friction modifer find a open lot and do about ten figure eights to work it into the plates
    asuchemist likes this.
  9. Dec 27, 2022 at 4:19 PM
    Clearwater Bill
    Billy
    Largo Florida
    And was the truck level, side to side and front to rear. If not any checking is less than accurate.
    If nose down or off side to side you can add too much. If nose too high you can't get enough in.
    Squirt[QUOTED] likes this.
  10. Dec 27, 2022 at 4:57 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio+ [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Let's assume the Valvoline fluid you used is the best you can buy with all the additives you need: That said: There are no symptoms until it whines, howls and fails.... (you'll know) Remove the filler plug on a level area when it's cool, and see if you get a steady stream out of the opening. If you don't: it's not full. Add fluid accordingly.
  11. Dec 27, 2022 at 8:08 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Thinking broadly and with the cold weather, do you use your parking brake often? If so, maybe it’s sticking.
    Smokestacks likes this.
  12. Dec 28, 2022 at 4:27 PM
    lordviews
    07 TRD Sport
    So I just added it today and I am stoked. Drove it around and it was a night and day difference. It no longer does anything and drives beautifully. Idk if it’s placebo but the vibrations are definitely gone. Thank you and everyone for the input. I really appreciate it!
