Low RPM hesitation
Discussion in '1st Gen. Tacomas (1995-2004)' started by smoothguy, Sep 1, 2011.
  1. Sep 1, 2011 at 4:34 AM
    smoothguy
    smoothguy [OP] Member
    jon
    east ky
    2000 tacoma 4x4 2.4 5 speed
    Just wanted to get your guys take on this and see what we can figure out.
    I have a 2000 taco 2.4 4x4 5 speed when I'm driving it at low rpm it has a hesitation in it but when I get it up over 3 grand it stops and smooths out. I have tried new spark plugs higher test gas injector cleaner nothing seems to be helping. I had a buddy tell me that it might be my mass air flow sensor needs checked. You guys have any suggestions
    Thanks
    Jon
  2. Sep 1, 2011 at 4:55 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The MAF is easily and cheap to clean. Disconnect, remove and spray with MAF cleaner. Make sure it's dry before you re-install. You also may want to look at the vacuum lines for cracks or leaks.
  3. Sep 1, 2011 at 11:11 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check/clean your Idle Air Controller, and check rubber/plastic parts of the air induction system for cracks/holes.
    Check your plug wires and coil packs for arcing. Dark garage, mist water onto a running engine, look for sparks.
