Low RPM + Oil Light
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Jan 8, 2015.
  1. Jan 8, 2015 at 5:36 AM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    So cold today, in the teens with wind chills lower. I noticed when I came to a stop, the oil light would come on. It appears than when stopped in gear, my RPM's would drop to about 500 (hard to tell, halfway between 0 and 1k). If I put it in nuetral the RPM's would go up and oil light go off.
    My only thought is the extra trans cooler is overcooling the trans fluid? When I get home tonight Ill check fluid levels but Im pretty sure its not low. Been driving it all week with no issues, just happened today.
  2. Jan 8, 2015 at 5:50 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    What weight oil are you using?
  3. Jan 8, 2015 at 6:16 AM
    Clearwater Bill
    Billy
    Largo Florida
    Why do you think this would affect the oil pressure light???
    The oil pressure light is activated off low pressure, not volume. If the oil is so low that the pressure drops (pan pickup is exposed) you have real problems.
    What wt oil are you running? Dino or syn? Is the truck up to full operating temperature when this is occurring?
  4. Jan 8, 2015 at 8:28 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Increased viscosity of the trans fluid causing the engine to bog down when in gear? In neutral, engine RPM's go back up to about normal (600-800 RPM's).
    Oil pump runs off the engine, I think. If the engine RPM's are too low, can the oil pressure drop?
    5w-30 Pennzoil Pure Plus Technology Platinum Ultra Extreme Plus (whatever; the highest end Pennzoil Synthetic - I can't quite make sense of their naming scheme). Yes, the engine was warm. Didn't notice it when it was cold, turned on after I got off the highway and hit my first light.
  5. Jan 8, 2015 at 8:55 AM
    Clearwater Bill
    Billy
    Largo Florida
    Nah. Eliminated because you say the vehicle is up to operating temp. Granted for some reason the engine isn't responding well to that load, but it's not because of trans fluid viscosity.
    Yes it does. Possible, but it doesn't take much to have the pump work. The pressure is measured by the oil filter anyway. I've seen pressure drop when the filter goes into bypass mode..........
    Great oil. Shouldn't be the issue. I'm assuming you don't have a CEL lit. But if you have a reader you might check for pending codes.
    Of course checking your fluid levels is always prudent.
    Let us know what you find.
  6. Jan 8, 2015 at 9:26 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You dont think the extra trans cooler and all the highway driving (lock up clutch engaged), would over cool the trans fluid? The oil pressure light only comes on when the engine RPM's dip down and they only dip down with the gears engaged (Park and neutral make the RPM's go back up and light go off). Maybe something is causing idle to be too low :notsure:
    Ill keep and eye on it and check fluid levels this afternoon. I need a trans temp sensor...
    No engine lights, Ill check pending codes.
  7. Jan 8, 2015 at 10:04 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Even wit h 500 RPMS light should not come on. If it does it means Oil pump is not giving enough pressure for pressure switch.
    That does not mean oil pump is bad, it could be oil switch, it could be oil filter having pressure valve stuck in open position, it could be bypass valve stuck open. It could be multitude of things
    Before anything I would check oil pressure at idle.
  8. Jan 8, 2015 at 10:14 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    500 is a geustimate. I need to hook up my computer to get exact RPM, but its right in the middle of 1k and 0. Generally its on the higher end, towards 1k (around 6-700ish).
    Oil pressure at idle in gear (500ish RPM's) = Too low (light on)
    Oil pressure at idle out of gear (N or P) (6-700ish RPM's) = Ok (light off)
    :notsure:
  9. Jan 8, 2015 at 10:21 AM
    BlueT
    NorthEast
    You should not be getting oil light at 500RPMS.
    You RPMS are not an issue, in fact minium oil pressure you should be able to get as soon as Engine fires (little faster than starter RPMS)
    So I would not focus on RPMS but rather why light comes on.
    Its either due to low pressure or faulty pressure switch
    if Its pressure switch that is a simple fix
    but if you are not getting minimum at 500RPMS than you need to find out exactly whats going on.
  10. Jan 8, 2015 at 10:31 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Light is comming on when RPM's drop below a certain point. It will start to flash as the RPM's begin to drop (when coming to a hault) and stay there until RPM's go back up.
    So what else is happening when the truck comes to a stop? What else is happening an parallel if the RPM's are not the issue?
    The only variable that changed this week was the temp, wind chill was sub zero this morning and temps in the teens. Only variable that changed between this winter and last winter was the trans cooler :notsure:
    Should I not drive it if the light comes on everytime I stop?
  11. Jan 8, 2015 at 10:36 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    As soon as I see a warmed engine oil light pop on at any time during driving, I pull over and check asap. It's the original idiot light for a reason. I was an idiot and ignored the thing once,,that's all it took.
    You made it home without exploding a engine it seems, so I would venture a guess that you did in fact have good pressure. You would have heard the thing make evil sounds as you ALMOST made the driveway home,,or another mile or two or three down the road after the light came on.
    BlueT nailed the high points on it.
    Not the first time super cold temps affected a high mileage switch. It's a pretty easy cheap switch, and while you are there you can adapt a pressure gauge to the fitting area to check running pressure. Build a T fitting setup for a in-cab gauge and your pressure switch, if you so choose.
  12. Jan 8, 2015 at 10:54 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Ill check the switch. Light only comes on when truck is stopped and goes off quickly as I start going again. I put the truck in N when stopped to keep the light off so Im not too worried but def was a bit rattled when it first came on.
  13. Jan 8, 2015 at 10:55 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Additionally while trouble shooting, keep in mind the minimum oil pressure (v6) at operating temp and idle speed of 700rpm +50 is a scant 4.3 psi so your working with a pretty small range.
  14. Jan 8, 2015 at 10:58 AM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Start with cleaning your mass airflow sensor.
  15. Jan 8, 2015 at 2:02 PM
    Clearwater Bill
    Billy
    Largo Florida
    That 'may' have some idle down function, and won't hurt anything regardless. Nor will cleaning the throttle body.
    But neither will correct whatever is happening with the oil pressure light, other than 'hide it' if the idle picks up again.
    Oil pressure should be in spec as long as the engine actually runs.
  16. Jan 8, 2015 at 3:16 PM
    Idaholandho
    Have you ever cleaned your throttle body?
  17. Jan 8, 2015 at 5:30 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Im with you on the switch. I check my MAF every time I change my oil an clean as necessary. I JUST installed a brand new OEM MAF.
    A while ago. Wasn't that dirty :notsure:
    Toyota.
  18. Jan 8, 2015 at 5:54 PM
    NSDON
    NSDON Well-Known Member
    Don
    NS
    02 SR5 TRD 4X4 Step Side
    Did you check your oil?
    If it was low, add oil.
    If it was low, has it been burning oil? If so, how many miles do you get to a quart?
    Has it been leaking oil?
    If it wasn't low, its likely a sensor. It has nothing to do with your MAF or your transmission, or anything else, just your motor.
    The light comes on due to low oil pressure caused by low oil (down more than a quart is what it would take to turn on the oil light) or by a faulty sensor.
    So, first thing, did you check your oil?
  19. Jan 8, 2015 at 6:06 PM
    40950
    CR, WA
    stock
    4.3 psi is basically a steady pour out of a pitcher(or less). Crazy light duty pressure switch if so. Definitely verify your operating temp idle rpms as stated above as you diagnose.
  20. Jan 8, 2015 at 6:11 PM
    BlueT
    NorthEast
    Check oil pressure first. Harbor freight has a kit that has toyota adapter for cheap. Take it from there.
    Do you have FSM ? There should be exact numbers that pressure needs to be at idle and high rpms. Before you check pressure everything else is speculation.
