Low RPM Shuddering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bsilvey, Dec 5, 2023.
  1. Dec 5, 2023 at 1:09 PM
    bsilvey
    bsilvey [OP] Member
    2012 Nautical Blue Tacoma TRD Sport
    2" spacer lift
    Need help diagnosing a shudder/violent vibration. It only occurs when driving between 35-45 MPH but most commonly at the 40 MPH mark and usually the truck is in 5th gear when it occurs. If I downshift the truck to 4th gear the vibration/shudder disappears immediately but I believe this is due to RPM's being higher.
    2012 Tacoma 4WD 196,000 Miles:
    -Bilstein 5100 (top setting, stock springs)
    -rear add a leaf (no idea branding, purchased truck second hand)
    -angled shims under leaf springs
    -new front CV axles both sides
    -needle bearing replaced
    -265/70R17 tires on Stock Wheels
    If anyone has any idea what to do to fix this I would greatly appreciate. Feel like I have banged my head over and over looking for answers and solutions with no luck.
  2. Dec 5, 2023 at 1:10 PM
    Maximumdarkside
    Maximumdarkside Master of self destruction.
    J
    Sevierville, TN
    2014 4Runner Limited formerly 2015 Tacoma Prerunner and so many more!
    Mostly stock, just getting it to my liking, just happy to have had the taco and now my 4Runner.
    Welcome to TW, research torque converter shudder, most likely culprit for most of us.
  3. Dec 5, 2023 at 1:16 PM
    bsilvey
    bsilvey [OP] Member
    2" spacer lift
  4. Dec 5, 2023 at 1:20 PM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    I had similar issues. 35-40mph with shuddering. I went to replace my VVT and ended up putting the old one back in, but just removing one and putting it back in actually helped. I still get the shudder at 40mph, but ONLY at 40mph. My finances aren't great right now, so I haven't replaced the VVTs, but that is on my next to do list.
    Check this thread out.
    https://www.tacomaworld.com/threads/2nd-generation-transmission-shudder.808889/
    Maximumdarkside likes this.
  5. Dec 5, 2023 at 1:30 PM
    bsilvey
    bsilvey [OP] Member
    2" spacer lift
    This thread seems to describe the exact issue - what it seems like is I need to differentiate between engine shudder and torque converter shudder to identify which one is the problem
  6. Feb 4, 2024 at 3:30 PM
    MaxTorque
    MaxTorque Hope is not a strategy...
    Maryland
    cup holders
    You are exactly right. Owners may be chasing an engine issue when it is really a trans problem. The torque converter clutch locks around 45mph. So if the shudder occurs then try disconnecting the electrical connector on the side of the trans for the TCC and test drive. This will keep the TCC from locking up and the shudder will disappear if its the problem. Not saying the torque converter is bad, yet. Worn out fluid is the cause of a lot of shudder issues. With 196K miles on your vehicle you should have changed the trans fluid 3X by now. If not, you would not be wasting time and money by doing this. Keep in mind that if you drain and refill you will be replacing only about 3 qts in a 10 qt transmission. So you may have to do this a few times to get all new fresh fluid in the trans. Or take it to a shop and have a "flush" and fill performed.
  7. Feb 4, 2024 at 5:27 PM
    Agoldxj
    Agoldxj Well-Known Member
    James
    Central Pa
    2009 SWB AC
    Drive it in “4” if it doesn’t shutter it’s the converter. Do a filter change and add some lubeguard anti-shutter. It will work for a while but will come back.
