Low RPM vibrations after fixing U-Joints! Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Markus9u, Feb 20, 2012.
  1. Feb 20, 2012 at 7:53 AM
    Markus9u
    Markus9u [OP] Markus9u
    Markus
    Texas
    2005 Texas Edition
    Borla Exaust system, Doug Thorley headers, Injen powerflow cold air intake, URD performance chip, Train horn w/ 150 psi, Bushwackers, RBP Grill, Westin Bull Bar, Piaa lights, HID Projectors 8K, Pioneer Avic-X 930bt, Remote start?Alarm.
    My truck has had a vibration in 2nd and 3rd gear at low rpms even when climbing up a small hill. I dont know what the problem is but its getting really anoying and i know Toyota will over charge me just to look at my truck. I have just replaced the U-Joints, any suggestions would help.!!:confused:
    Also, i have a small lift AAL(Add A Leaf) in the back 2.5 and a 2 inch spacer in the front.
  2. Feb 20, 2012 at 8:57 AM
    badger
    badger Well-Known Member
    07 SR5
    Did you replace the center ujoint? Did you mark the drivelines so they went back together the same way they came apart? If not, that is your problem.
  3. Feb 21, 2012 at 12:55 PM
    Markus9u
    Markus
    Texas
    2005 Texas Edition
    I replaced all three. But i did not mark anything i just put the shaft back in after replacing.. Could i get it rebalanced or something like that?
  4. Feb 21, 2012 at 6:17 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Did you disassemble the slip spline? If not, turn the shaft 180 deg at the center, and try it again. If you did have the slip joint apart, the the yokes on the same shaft have to be lined up with each other for proper phasing of the ujoints. And either way, yes, it could be reballanced by a driveline shop, but it's not cheap.
    And, just to clarify, did this start happening after the new ujoints, or was it there before?
  5. Feb 21, 2012 at 6:43 PM
    badger
    07 SR5
    ^^what Phil said. The driveline is balanced as a unit so it must be put back together as such. There are only 2 possibilities at the center ujoint, so try swapping them 180 as Phil said. If you didn't pull the splines apart, then that should return you to good balance. Normally all the grease zerks are on the same side for ease of maintenance. Hopefully you put them back that way.
  6. Feb 27, 2012 at 7:31 AM
    Markus9u
    Markus
    Texas
    2005 Texas Edition
    Okay, so i disassembled the whole shaft from my truck, put it i n my bed and replaced all U-Joints. This is the second time i have done this.(not happy) but the vibrations went away the first time. Now their back and when its super low torque on the truck the vibrations happen so i let go of my gas peddle and they stop. Would this be my truck needing new rear differential fluid? Maybe, new automatic transmittion fluid. Im confused on the 180 degree turn?? and slip joints,splines and yokes.. Thanks for the help guys!!
  7. Feb 27, 2012 at 9:17 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    The slip spline is the "expansion joint" in the rear section of the shaft, and on these trucks has a rubber boot on it with crimped on clamps, so you would have had to intentionally disassembled it. A yoke is the part welded to the shaft tube that the u joint fits into , or the flanged yokes that bolt to the diff, tranny... Since there are two possible ways to assemble the two sections of the shaft together, turning it 180 degrees, or 1/2 a turn, will possibly restore the balance if it is currently assembled opposite of how it was when the assembly was balanced.
    I'm still confused though. Did changing the ujoints start the vibes, or is it just that it didn't cure it this time?
  8. Feb 27, 2012 at 11:04 AM
    badger
    07 SR5
    I'm confused too :confused: What do you mean it went away the first time? You didn't need to replace the Ujoints the second time. All you needed to do was seperate the center joint, rotate one of the shafts 180 degrees and reassemble. If you had separated the slip splines, then you also would need to get those back in line as they were originally. There are potentially 2 posibillities there that would appear right as well.
    If you just repeated the same wrong procedure, then you'll get the same wrong result. You might have to just take this to a DL shop and get them to set it right. I'll bet they do this 2 or 3 times a day. I don't know why the damn shafts are not marked when they are assembled originally. That would make too much sense I guess :rolleyes:
  9. Apr 9, 2012 at 11:09 AM
    Markus9u
    Markus
    Texas
    2005 Texas Edition
    Sorry for the long wait on the reply guys.! but i have found and cured the problem! My truck now has 142,000 miles on it, never changed any fluids except for the oil every 4,000 miles... With that being said the vibrations were from the automatic transmittion fluid being super old! I replaced and flushed the system with another threads help making my truck now feeling like new!! I love the way it drives now without any vibrations and bogging down on the engine. From now on i am going to change this fluid reguarly(I also did the rear differentials). Now running synthetic oils which to me feel much cleaner and better performance all around!
  10. Jun 11, 2013 at 1:13 PM
    sschneider
    sschneider Member
    Scott
    Georgia
    06 X-SP Texas Edition
    X-SP Package 20' inch Enkei Wheels Borla Exhaust Carbon Fiber interior JBL Speakers Nitto Terra Grappler Tires
    i have 112,000 miles on my truck and just replaced all 3 U-Joints. That solved most of the problem but I am still getting a random vibration when accelerating in low gear. The vibration goes away after I speed up or slow down. I read something about rotating my drive shaft 180 degrees? Does it sound like the same problem you had?
  11. Jun 16, 2013 at 11:55 AM
    Markus9u
    Markus
    Texas
    2005 Texas Edition
    Try a full flush on the automatic transmission fluid their should be a thread on "HOW TO". That's what fixed me up.. best of luck
