Low spark?
Discussion in '1st Gen. Tacomas (1995-2004)' started by brienm, Jul 6, 2017.
  1. Jul 6, 2017 at 7:41 AM
    brienm
    brienm [OP] New Member
    Brien
    96 2.4 litre tacoma ext. cab, standard transmission
    Hi,
    I have a 96 2.4 l tacoma stand. trans. Last year it quit suddenly. I changed the mass air flow sensor and it ran perfectly for a year. It just began running rough, stalling, sometimes hard-starting. I ran a diagnostic = P0171 and P0420. I checked the catalytic converter and it had a crack ... changed that and the two O2 sensors. This cleared the codes but didn't help the problem. Also checked all my air filter, lines, etc...didn't see anything. Took it to a mechanic he told me it had low spark. He wants to change the distributor and the coil. I can see the coil but the distributor? Expensive repair ... not sure this will fix things. Any suggestions?
    Thanks.
    Brien
  2. Jul 6, 2017 at 7:58 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Take it to another mechanic.
    ThunderOne likes this.
  3. Jul 6, 2017 at 10:19 AM
    Glamisman
    Glamisman Well-Known Member
    I am seeing aftermarket / rebuilt units for < $100.
    For a less expensive "test" I would replace the cap and rotor with the same brand. The reason I am saying same brand is that a number of years ago the parts store had the cap but no rotor. Went to another parts store for the rotor but it was from a different manufacturer... while it all worked the mpg dropped by 3mpg... I went through my notes and remembered the issue and bought a replacement cap/rotor from the same manufacturer and my mpg came right back... the air gap between the 2 different components apparently was enough to cause an issue.
  4. Jul 10, 2017 at 9:33 AM
    taco71742
    taco71742 Well-Known Member
    Daniel
    Woodstock GA
    04 Taco DC 4x4 5spd
    3" Toytec Boss Lift with External reservoir and adjusters Prerunner to 4x4 conversion Manual locking hubs 16x10 w/-38 offset 305/70r16 Toyo RT tire
    I would go with ^ his route. If that doesn't fix things you can replace the coil pack.
  5. Jul 10, 2017 at 10:10 AM
    JaBoudy
    JaBoudy Accidental Thread-Jacker
    Josh
    Florida
    1995.5 Tacoma 4x4 v6 5 spd 321k miles.
    -Fabtech 6" in front, OME/Toytec 5" rear with Dakar leafs. -Deck plate mod -Chassis Unlimited front bumper -Badlands 12k winch -33x12.50x15 BFG KO2's -15x10 American Racing AR-23's -Audio System -Kenwood Receiver -Powerbass PS12 -Rockford Fosgate R1 -Bridged Concept 65.4 Amplifier -Polk Audio component 5.5" door and 1" tweeter speakers -Polk Audio crossovers -JL Audio rear 6.5" speakers -Black-housed headlight with Amber SMD halo ring. -Exhaust Setup -2.5'' Pipe, cut cats, 18" MagnaFlow, dumped at the rear bumper.
    I'm not familiar with the 2.7s, but if you're handy I'd recommend cleaning the throttle body and idle air control valve. Cheap solution that may fix it.
    I had similar issues with my 3.4 and that solved it. To me it was worth trying over throwing money into new parts.
  6. Jul 10, 2017 at 10:50 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Someone correct me if I'm wrong, but if you have a 2.4l then you have a distributor. Not coils. You cannot have both a distributor and coils. You either have one or the other. Try changing the distributor and rotor first. It should be a 5 minute job.
  7. Jul 10, 2017 at 11:06 AM
    taco71742
    Daniel
    Woodstock GA
    04 Taco DC 4x4 5spd
    The 1998 2.4 usually have 2 coils packs instead of having a distributor. Distributors have a coil pack built in
  8. Jul 10, 2017 at 11:17 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Ah, so very similar to the 3.4L then. You could try swapping the coils around to see if your misfire moves to a new cylinder. That will narrow down which coil has gone bad.
    JaBoudy likes this.
