Low speed brake shudder 2018 TRD Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mikesixtysix, Mar 17, 2018.
  1. Jan 23, 2019 at 4:03 PM
    #61
    Bogard
    Bogard Well-Known Member
    Bill
    Pennsylvania, USA
    Be sure to check out TSB 0023 18, which exactly describes the condition and technical proceedures required. This TSB was for trucks up to certain VIN not for my truck or yours. I took a copy of it to the dealer none the less because it pertains to the same issue. Just a guess but I believe it will be updated in the future to cover additional VIN#.
    Cl4aub likes this.
  2. Jan 23, 2019 at 7:08 PM
    #62
    jekerskel
    jekerskel Well-Known Member
    Zach
    Bellingham WA
    2004 SR5 Extended cab 2wd 5 speed
    V-LED low and high beam headlights.
    I have had my rear drums turned once and now 15k later they are warped again. U can pull up on the e brake to stop u and u can tell. The rear drums from
    Toyota are warped. From the factory and the box. Very common issue.
    SaulGoodman likes this.
  3. Jan 23, 2019 at 7:46 PM
    #63
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    My 2016 did something like this. Dealership found improper pinion angle, but there was no fix back in the day. They agreed it was out of spec, but they told me I had to live with it. Later on some updated springs were released, which had mixed results. It felt like I was driving over a rumble strip when dropping below 20 MPH.
    The 2nd and 3rd gen trucks are so sensitive to driveshaft angles, and the leafs allow for a lot of axle wrap. If I buy a 3rd gen, I'm going to test drive the hell out of the truck before I sign the paperwork.
  4. Jan 28, 2019 at 4:34 PM
    #64
    Bogard
    Bill
    Pennsylvania, USA
    Update 3
    Heard from Service manager today. They have opened a case and are proceeding with axle replacement, new bearings etc.
    Will report back when work is completed.
    So far: near front rotors new rear drums.
  5. Jan 28, 2019 at 5:09 PM
    #65
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    I hope you have more luck than I did with the axle TSB , it didn’t make a difference for mine . Please post up whatever success you have as a lot of 2018 seem to be experiencing this.
    Skull likes this.
  6. Jan 29, 2019 at 5:54 PM
    #66
    Bogard
    Bill
    Pennsylvania, USA
    The service manager did explain they need to be sure that the replacement parts are not just a repeat of defective factory parts. They will be making measurements to assure that the new parts are not just a repeat. Makes sense. We shall see.
    Skull and turbosnail[QUOTED] like this.
  7. Jan 29, 2019 at 6:20 PM
    #67
    turbosnail
    Pa
    Actually starting to think it’s driveshaft/ ujoint related. I’ve ruled out almost everything else. Looking forward to your results
    PuyallupJon likes this.
  8. Jan 30, 2019 at 2:45 AM
    #68
    Skull
    Skull Well-Known Member
    Karl
    NC
    2019 White TRDPro
    ....and 2019
  9. Jan 30, 2019 at 5:58 AM
    #69
    gw204
    gw204 Well-Known Member
    My '18 SR does it. I get the same sensation under hard acceleration as well...so it either has nothing to do with brakes or I have multiple issues.
    turbosnail and Skull like this.
  10. Jan 31, 2019 at 9:21 AM
    #70
    Bmobuell
    Bmobuell Member
    Bryan
    19 TRD sport
    Hey, I have 19 dcsb, decel/braking under 30mph vibration also. Also have the fast vibration under hard accel at the top of first gear. Was going to disconnect driveshaft (make it fwd in 4wd) to see if it’s tge driveshaft or angle .....
    But it’s super cold here, maybe a springtime job.
    It’s a lease, so I’m not crazy concerned. Mostly just a bit annoying.
    If it was mine I would deff be in the dealer ASAP. No brand new 2019 vehicle should vibrate or shutter!! Period.
    Skull likes this.
  11. Jan 31, 2019 at 12:26 PM
    #71
    SaulGoodman
    SaulGoodman Well-Known Member
    24 SR5 4x4
    2019 owner here, mine is going to see the dealer next Wednesday, will report back. No vibration on accel, but slight shaking of cab (not pedal or steering wheel) when braking around ~40%. Mine dissapears if you press harder or less, so I'm keeping fingers crossed its just drums out of round.
  12. Jan 31, 2019 at 12:36 PM
    #72
    Bmobuell
    Bmobuell Member
    Bryan
    19 TRD sport
    It’s kinda hard to do/notice..... but I don’t think it’s brakes because when braking and it gets to 25mph or so the vibration starts. But if I let off quickly (about 15mph) and am coasting the vib continues for a sec or so. Then the truck is going slow enuf it goes away (10mph or so)
    turbosnail likes this.
  13. Jan 31, 2019 at 2:56 PM
    #73
    turbosnail
    Pa
    This is exactly what my truck does .
  14. Jan 31, 2019 at 3:07 PM
    #74
    Carter'sTaco
    Carter'sTaco Leave anything for us?....Just bodies.
    Carter
    The Desert..........Arizona.
    "Gloria" 2018 SR 4x4 DCSB
    King 2.5" Front w/adj.- TC UCA's- King Ext rears w/ adj.- ICON RXT's- Avid Offroad Rock sliders- RCI Skids- Onboard ARB in EE cubby- EE TPAM- s48o diff breathers kit- Exhaust re-route- Falken Wildpeak 32" AT3-W Spintech 3000 muffler- Uniden CB / 3' Firestik- Ultra Phantom 16x8's- Fog lights- Tint- TRD rubber floor mats- Seat covers- AC drain mod- Hood decal- Custom headlight wrap- K&N Filter- Cali rasied switch panel- Cali rasied Ditch bracket mounts-
    There is a recall on the master cylinder and front brake assembly. Toyota just gave me back my truck after 4 days of waiting for my new front brakes to come in. Recall complete, brakes feel different, no more bobble or stumble feel when pressing at low-low speed. Check your VIN! Riverview Toyota in Mesa, AZ just did my recall!
  15. Jan 31, 2019 at 3:16 PM
    #75
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    I have an '18 OR and mine does the same but not all the time. Since it it doesn't happen all the time. I'm concerned that they won't be able to replicate it and then give me some excuse that it's normal or something like that. I have my 5k appointment next Tuesday and I'm going to mention it to the service guy. Let's see what they tell me.
    Skull likes this.
  16. Jan 31, 2019 at 3:16 PM
    #76
    rblalliance
    08 TRD OR DCSB 4X4
    Thanks! Going to check my VIN tonight.
  17. Jan 31, 2019 at 3:19 PM
    #77
    Carter'sTaco
    Carter
    No problem!
    Lucky me has had EVERY SINGLE TSB or recall on my truck from day one! ALL OF THEM! Over 7 TSB's and 3 recalls on my truck in only 7 months and 12k miles of existence!
    I feel all your pain! Annnnd......for some reason I still love her....:annoyed:
  18. Jan 31, 2019 at 3:27 PM
    #78
    rblalliance
    08 TRD OR DCSB 4X4
    Just checked my VIN and no recalls. Let's see what the dealer tells me Tuesday :fingerscrossed:
  19. Jan 31, 2019 at 3:32 PM
    #79
    Carter'sTaco
    Carter
    Good luck my friend. What has worked for me is making sure they know Im not bitching or whining...I just want my new truck to sound and drive like a new truck. I always use my kids as a realistic leverage to make sure this truck is as safe as its supposed to be. Definitely not right to have to "finagle" a manufacturer to fix their truck, but it is what it is!
    Im off to fight for Toyota to fix this new rapid and loud "chirp" damn High pressure Fuel pump's! F'n toyota!:angrygirl:And another one!
  20. Jan 31, 2019 at 3:34 PM
    #80
    rblalliance
    08 TRD OR DCSB 4X4
    Thanks and good luck to you
    Carter'sTaco[QUOTED] likes this.
