Low speed vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SaltSeaTaco, May 15, 2021.
  1. May 15, 2021 at 10:51 PM
    SaltSeaTaco
    SaltSeaTaco [OP] Active Member
    So I installed a 2 inch lift on my 2019 tacoma trd off road it is 2wd and yeah I know should've gone 4wd but too late now(mall crawler) lol but yeah anyways also installed some 285 70 17mt g003 at same time and now I'm experiencing some vibes . Driving me crazy under 5mph from what I could tell, also did install some 2.5 degree shims in the hopes it fix the issue but no nothing vibes still there anyone have any idea what it might be? Feels like a small vibration from underneath the front seats or center of vehicle too hard to pin point .
    Any helps would be greatly appreciated thanks .
  2. May 15, 2021 at 10:52 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Did you drop the carrier bearing at all?
    Which way are your shims pointing? Thin end should be to the rear.
    And how did you know you needed angle shims? Did you measure your flange angles at all before installing them?
    What kind of lift?
  3. May 15, 2021 at 11:04 PM
    SaltSeaTaco
    Yeah that's weird 2 inch lift all around bilstein 6112/5160 with add icon add a leaf No measurement just trial and error but it's definitely next is to start measuring angles. Tried carrier bearing as well and didn't help .
  4. May 15, 2021 at 11:59 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    It's the tread on your mud terrains. It's the only thing that's going to have enough frequency to give a vibe at >5 mph.
    Overinflation can make it worse; you should be at about 32 psi.
    71tattooguy and bulalo like this.
  5. May 16, 2021 at 6:23 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    All i can say is when a buddy installed a 3'' rough country lift in his 2019 trd. He had vibrations he didn't notice before. He got rid of the lift months ago, and the truck is now far more enjoyable to drive. I guess if you really need a lift thats one thing, but you have to expect more than average vibration issues they can cause.
  6. May 16, 2021 at 6:25 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Did you do your ECG’s bushing?
  7. May 16, 2021 at 6:32 AM
    splitbolt
    NW Arkansas
  8. May 16, 2021 at 6:50 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    2WD TRD off-road is a thing?
  9. May 16, 2021 at 6:59 AM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    Do u still have your stock wheels
  10. May 16, 2021 at 7:00 AM
    Bishop84
    Bishop84 Well-Known Member
    MT003's vibrate, get used to it.
  11. May 16, 2021 at 7:10 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Thin end to the rear would point the front of the diff down. That doesn't seem right if trying to reduce driveline angles
  12. May 16, 2021 at 8:31 AM
    SaltSeaTaco
  13. May 16, 2021 at 8:32 AM
    SaltSeaTaco
    Oh I will they look so good lol
  14. May 16, 2021 at 8:33 AM
    SaltSeaTaco
    Yeah thin side forward towards front and don't have stock wheels anymore sold them when I bought the truck but I'm guessing now it's the tires g003s have pretty aggressive tread.
  15. May 16, 2021 at 8:34 AM
    SaltSeaTaco
    Crazy right lol locker definitely helps though but not taking my 35 thousand dollar truck on crazy trails anyways
