Low speed vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mountain_medicine, Dec 19, 2022.
  1. Dec 19, 2022 at 9:58 AM
    mountain_medicine
    mountain_medicine [OP] Well-Known Member
    Abram
    2020 Cement Tacoma TRD Offroad
    I'm hoping to get some insight from the community on a recent vibration in my 2020 TRD OR.
    I've been experiencing a very mild vibration (entire truck) that seems to occur during deceleration at the speeds of 20-23mph. It occurs whether I'm applying the brakes or not and there is no vibration/pulsation in the brake pedal. It's a manual so I've also put into neutral, and it still occurs. There is no associated noise/grinding. I also tried driving in 4WD and the vibration still exist (no worse/better).
    The truck is lifted 2.5" and drives true so alignment seems relatively good (aligned approximately 2,000 miles ago). I have replaced the needle bearing with bushing. I have BFG KO2s (~2,000 miles). Tire pressure all around is 30psi (a little low, I know but increases when tires warm up).
    The vibration seems to have developed recently. Temperatures have been in the 10-30F. I feel the vibration lessens/resolves after driving for a while which I associated with increased heat in the tires/increased PSI; but, not entirely sure.
    I know it's a truck and not a Cadillac. I don't recall this happening last winter; however, the truck was on stock tires and suspension then as well.
    Any insight would be appreciated!
  2. Dec 19, 2022 at 10:03 AM
    eurowner
    eurowner Duke Sky
    Scoty
    What lift?
  3. Dec 19, 2022 at 10:12 AM
    mountain_medicine
    Abram
    FOX 2.5 Reservoir (without DSC) front and rear, SPC UCA, and Icon AAL.
    eurowner[QUOTED] likes this.
  4. Dec 19, 2022 at 10:53 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    You answered your question. It's the combo, of cold temps and tire pressure.
  5. Dec 19, 2022 at 11:07 AM
    mountain_medicine
    Abram
    Seems reasonable. Just figured I'd get the braintrust to weigh in on similar experiences!
    na8rboy[QUOTED] likes this.
  6. Dec 19, 2022 at 11:37 AM
    na8rboy
    WI
    The cold weather/Temps bring on sorts of noises/feels. Highs here this week in single digits, low in negatives. I expect that shnit.
