LOW TIRE AIR INDICATOR
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JDTRAVEL, Feb 7, 2018.
  1. Feb 7, 2018 at 6:28 AM
    JDTRAVEL
    JDTRAVEL [OP] Member
    JD
    2007 TACOMA
    I've checked all 4 tires; pressure fine; increased PSI to super high then reduced; not solved;
    Could the spare be the culprit?
  2. Feb 7, 2018 at 6:37 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I had no idea why that little icon lit up on my dash last year so I took it down to the tire shop and asked them about it, they did some checking and found out the spare was indeed the culprit, they added 10 psi and the low air indicator went away.
    JDTRAVEL[QUOTED][OP] likes this.
  3. Feb 7, 2018 at 6:39 AM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Try them all inflated to 36 psi. If no joy, it might be time for new batteries
  4. Feb 7, 2018 at 6:41 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Put some air in your tires then hit the reset button under the dash
    JDTRAVEL[OP] likes this.
  5. Feb 7, 2018 at 6:42 AM
    JDTRAVEL
    JD
    2007 TACOMA
    Thanks bluezzy
  6. Feb 7, 2018 at 6:47 AM
    JDTRAVEL
    JD
    2007 TACOMA
    Reset button?? Where is that?
  7. Feb 7, 2018 at 6:48 AM
    JDTRAVEL
    JD
    2007 TACOMA
    Tacosail: Batteries? Where?
  8. Feb 7, 2018 at 7:19 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Some years have a TPMS sensor on the spare, some don't. The sensor is part of the valve on each tire, and has an internal battery.
  9. Feb 7, 2018 at 7:26 AM
    JDTRAVEL
    JD
    2007 TACOMA
    Okay, the battery is on the spare. Got it. Thanks
  10. Feb 7, 2018 at 8:04 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    The battery is on all tires with a tpms sensor.
  11. Feb 7, 2018 at 8:10 AM
    Tacosail
    Jerry
    '13 white ACLB
    X2
  12. Feb 7, 2018 at 8:15 AM
    Muddinfun
    Muddinfun Well-Known Member
    When I bought my truck, the TPMS light was on. We made sure the tires were aired up. The light was still on. The temp/ direction thingy was out. I told the car lot both were probably expensive fixes and talked them down a little more on the price. After I bought it, I found out from TW that the spare has a sensor and that the temp direction thingy just needed the resistors soldered. Both free fixes.
  13. Feb 7, 2018 at 8:31 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Why not just dissable the tpms light? Super easy to do and never need to worry about that annoying light again. Plus it saves $$$$
  14. Feb 7, 2018 at 8:46 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    Since the OP's truck is in 07, like mine, good chance the batteries in one or more of the sensors are dead. They last 7-10 years, mine I think lasted 10. You have a couple of choices from least expensive to most expensive under the assumption they are dead. Check that reset button first as mentioned above.
    1. Ignore the dumb light on the dash and do like everyone had to do b4 the dumb LTPS were mandated: periodically check the tire pressure, always take a glance at the tires when walking up to the truck that they don't look low.
    2. Search the forum for what 757yotas describes
    3. By all new sensors and search the forum for the method of placing them in a sealed tube in the vehicle to trick the computer to think you have good sensors.
    4. By all new sensors and have them installed in all five rims. Tires have to be removed from each rim in order to do this.
  15. Feb 7, 2018 at 8:52 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    If I get to that point I'll just place a sticker over the light. But # 3 above is interesting.
  16. Feb 7, 2018 at 9:06 AM
    Muddinfun
    If Scangauge ever gets it worked out so that you can easily switch to alternate screens, you will be able to check the pressure in all your tires with a simple push of a button.
  17. Feb 7, 2018 at 2:16 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There is a sensor in the spare on 2007 models. Check it.
  18. Feb 7, 2018 at 2:35 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Does the light blink when you turn the truck on? if so you have a dead battery in a TPMS sensor (each one has an individual battery which is mounted to the valve stem inside your wheel) Air up to 34-36 psi in all tires including the spare.Then turn ignition on and hold the button under the steering wheel for a decent amount of time. Should fix it.
