Low tire pressure light come on and tires are low every time it goes below 30 degrees
Discussion in 'Wheels & Tires' started by JghTT17, Jan 26, 2018.
  1. Jan 26, 2018 at 6:50 PM
    JghTT17
    JghTT17 [OP] Member
    Jim
    PA
    I bought this truck in April so this is my first winter with it. And every time it gets colder
    Than 30 the low tire pressure light comes on and off to the gas station I go. I live in PA. So this will be all winter and 1.00 for air every time. Is this common? Any remedies? I have the alloy stock rims on my 2011 tacoma sport. Any help I’d appreciate!
  2. Jan 26, 2018 at 6:53 PM
    F34Rnnr
    F34Rnnr Active Member
    Mine did the same, and it was a TPMS leak. Might be worth getting a TPMS stem rebuild so you get new gaskets.
  3. Jan 26, 2018 at 6:54 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    The colder it gets the less air pressure your going to have in your tires. If your driving to the gas station to fill them your tires are warming up on the way there and will be at a higher pressure than when they cool off. Fill them a little higher or reset the TPMS when they are cold
    tcBob, Gunshot-6A and InfernoTonka like this.
  4. Jan 26, 2018 at 7:06 PM
    Muddinfun
    Muddinfun Well-Known Member
    How about check it with a gauge and see if any of the tires are actually leaking? If you are repeatedly putting in more air, you have a leak.
    InfernoTonka and Jimmyh like this.
  5. Jan 26, 2018 at 7:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This.
  6. Jan 26, 2018 at 7:35 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Put air in them.
    SH7mi, Cudgel and Boyk1182 like this.
  7. Jan 26, 2018 at 7:39 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    I thought there was a way of setting the system so it only lights up when you are 10 PSI below recommended pressure.
    I haven’t had this happen since I had new tires installed over a year ago with temps ranging from 10°-100°.
  8. Jan 26, 2018 at 8:08 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is how it works. Air the tires up to where you want them then use the TPMS Reset procedure in the owners manual to set that pressure as the reference.
  9. Jan 26, 2018 at 8:55 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    My understanding is per federal requirement, TPMS lights up when any tire drops 25% below whatever it was when the system was last reset. So if 32 when last reset (either 1 tire or multiple) drop to/below 24 the dash lights up. And as mentioned above will go out if you drive enough to warm the tires up and get pressure to/above 24.
  10. Jan 26, 2018 at 9:57 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It is basic physical science. When temps are hot air pressure increases, when it is cold air pressure decreases. This has been happening as long as people have been using pneumatic tires. People who check the air pressure in tires have always had to do this when the weather gets cold.
    InfernoTonka likes this.
  11. Jan 28, 2018 at 9:34 AM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    What tire pressure are you running? Do you have a decent tire gauge?
    Try this :
    Air up your tires to 38 at your gas station.
    Next morning (at home) adjust pressure to what you want before driving - try 32. Do this early am, and if parked outside before sun gets on tires.
    Follow instructions from your owner manual to reset TPMS.
    If you still have a problem, you DO HAVE A Leak or a failing battery in one or more of your TPMS sensors.
  12. Jan 28, 2018 at 9:40 AM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    If I understand correctly, aluminum rims bleed a certain amount of air, not quickly, but over time they do. Coupled with cold temperatures you will need to put some air in from time to time. Side note, $1 for air!? Go get yourself a little 1 gallon air compressor and enjoy your unlimited nearly free air.
  13. Jan 28, 2018 at 9:50 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Alloy wheels are notorious for this. On cold days, mine will increase 5 -7lbs once I start driving & they change from square to round. But this is extreme cold. If it persists, get the wheel beads cleaned, apply a thin amount of bead sealer & you should have no problems. $1.00 for air? Started when service stations became gas stations. Sad.
  14. Jan 28, 2018 at 9:55 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  15. Jan 30, 2018 at 9:21 AM
    Muddinfun
    It takes a special kind of ____ ____ to ask a question and not stick around or come back to check for answers.
  16. Jan 30, 2018 at 9:31 AM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    Give the OP a break with the sarcasm, he hasn't been a member too long and has only 14 posts to this point.
    OP, mine does the same in the winter, its not an issue as others have stated. I have a little compressor I keep in the garage just for this.
  17. Jan 30, 2018 at 9:48 AM
    Muddinfun
    It has nothing to do with how long they've been a member or how many posts they have. It's common courtesy. If I needed to know what to set the fidget valve clearance at on my XC81C Widget, and I asked on a public forum, I would be checking for answers every 5 minutes and thanking those that answered.
  18. Jan 30, 2018 at 10:54 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Half the reason I put an air compressor in my truck is because I never had quarters to run the gas station air compressor...when you find one that actually works. Works really well for little stuff like this.
    But like others have said, temperature and pressure are directly related. Mssr. Gay-Lussac would like a word:
    https://en.wikipedia.org/wiki/Gay-Lussac's_law#Pressure-temperature_law
  19. Jan 30, 2018 at 9:15 PM
    Big2Customs
    Big2Customs Well-Known Member
    2007 Tacoma TRD Sport. Indigo Ink
    Bilstein 5100 front Bilstein 5100 rear
    One more thing ...
    There is a 5th TPMS sensor ... On the spare!
    My TPMS light kept coming on even though I was certain the pressure on all 4 were matched and good. I flipped my spare to have the valve facing down and towards the rear so I could access it.
  20. Jan 30, 2018 at 9:19 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Never had this problem with aluminum wheels.
    But, I use All Season Air so that helps.
