Low Tire Pressure Light not turning off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco09TRD, Feb 17, 2018.
  1. Feb 17, 2018 at 5:20 PM
    Taco09TRD
    Taco09TRD [OP] Member
    Houston, TX
    09 Silver V6, SR5, Prerunner, TRD Sport
    18" Rims and Tires
    Hello fellow Taco owners! I am having a problem with my low tire pressure light, in which that it will not turn off.
    Every time I turn my truck on, it blinks for a couple minutes before coming solid, and the thing is that my tire pressure is perfectly fine (which I have checked plenty of times). When I took it to NTB and Drivers Auto for inspection, they could not figure it out for some reason.
    Any suggestions to why it is happening?
    Thanks.
  2. Feb 17, 2018 at 5:21 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Fill up all your tires including the spare tire. If that doesnt work just go to tire shop get the sensors reset
  3. Feb 17, 2018 at 5:21 PM
    bad092276
    bad092276 GEAUX TIGERS
    Brad
    Louisiana
    2016 Silver Sky
    did you check the pressure on the spare?
    BAMFTACO likes this.
  4. Feb 17, 2018 at 6:09 PM
    Pigpen
    Dan
    Northwest Montana
    The sensors have about a 10 year life expectancy. If topping off all 5 tires doesn't do it, they may be going out.
    williegator likes this.
  5. Feb 17, 2018 at 6:22 PM
    Taco09TRD
    Houston, TX
    18" Rims and Tires
    BAMFTACO I tried getting the sensors reset, so I will go ahead and check the spare for sure then. Thank you!
  6. Feb 17, 2018 at 6:27 PM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    09's have no sensor in spare. Turn on truck hold reset otton under steering column, see if that works then. Did you just get new tires and rims? New sensors?
  7. Feb 17, 2018 at 6:29 PM
    Pigpen
    Dan
    Northwest Montana
    I'm guessing dead batteries in the sensors - it's that Texas heat
    JDawg562 likes this.
  8. Feb 17, 2018 at 6:34 PM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    This is easy, one of your sensors is toast. Go replace it or all of them they are cheap on Amazon.
  9. Feb 17, 2018 at 7:05 PM
    BAMFTACO
    Juan
    Kings bruh
    Nice to know and looks like the op has a trd sport figured it might have a sensor. But yeah if that doesnt work then sensor most likely bad
  10. Feb 17, 2018 at 7:53 PM
    JDawg562
    JDawg562 Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
    In 2009 they started to take them out of the spare. Some 2005 had them, some 2009 might have them, and some of the newer 2009 do not. From when I looked up mine a while back.
    OP mine did the same thing. I tried resetting them with the button, filled them all up including spare. Then took it down to american tires and they checked the sensors for free turns out one of the batteries died in the TMPS. I bought a set of 5 Denso ones off Amazon. https://www.amazon.com/gp/product/B00NQ05U24/ref=oh_aui_detailpage_o08_s02?ie=UTF8&psc=1 Since Denso makes a lot oem stuff for the Tacoma and american tires wanted like $80 per sensor.
  11. Feb 17, 2018 at 7:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Blinking light means one or more dead sensor(s).
  12. Feb 18, 2018 at 7:04 AM
    Tiedie
    David
    WFOY
    These are the one's I got off Rockauto.
    http://www.rockauto.com/en/catalog/...ressure+monitoring+system+(tpms)+sensor,12036
  13. Feb 18, 2018 at 11:02 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I got some oem 2015 Taco Steel wheel tpms sensors in the BST section if anyone needs some.
  14. Feb 18, 2018 at 11:08 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Does a 2011 spare tire have one?
  15. Feb 18, 2018 at 11:13 AM
    Clearwater Bill
    Billy
    Largo Florida
    Don't think so.
    Pretty sure you can just look at it to know if it's a conventional valve stem or one with a sensor.
  16. Feb 18, 2018 at 11:14 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    thanks , ill go look
  17. Feb 18, 2018 at 12:54 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Ever figure it out?
  18. Feb 18, 2018 at 1:09 PM
    flightmech08
    flightmech08 Well-Known Member
    Hillsburgh, ontario
    2007 trd double cab 4x4 6 speed
    old man emu lift kit with full dakkars. ARB front locker, rear dif vent mod 1.5" spacers
    Sounds like a dead battery, sensor batteries are only good for about 8 yrs I have the same problem. I just live with it for now.
  19. Feb 18, 2018 at 1:19 PM
    Vereor_Nox
    Vereor_Nox Fumblerooski
    North California
    2010 Tacoma TRD Sport
    If I would have listened to all the "sensor is toast" comments I would have been out a couple hundred dollars.
    My truck did the same thing one morning. I filled up all the tires including spare and reset the tpms per manual but nothing seemed to work. Later that week I ended up going out of town for dinner (about 45min drive) and my tpms light turned off.
    Before you go replacing anything set everything to factory manual setting and take the truck for a good drive, the tpms may need time to register the proper psi. Also tires heat up as you drive which affects your tire pressure.
  20. Feb 18, 2018 at 2:38 PM
    Tridet167
    Tony
    Toronto, Canada
    My issue started when I put on new larger tires. The truck was purchased used and had two sets of tires, stock and set of snows. Following the manual, I can't get it set to the new tires. I read somewhere that the ECU only has two memory slots for readings. If that's true then that would explain my problem. Anyone hard of that?
