Low tire pressure light weirdness
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Geoff.in.nc, Oct 25, 2019.
  1. Oct 25, 2019 at 1:59 PM
    Geoff.in.nc
    Geoff.in.nc [OP] Hey y'all, watch this!
    Geoff
    Fayetteville NC
    '23 Silver DCLB Sport (my 3rd Taco!)
    2008 DCLB 4.0 prerunner 173k.
    Today while driving down the highway my low tire pressure light started flashing for a few minutes then came on solid. I pulled off and checked tire pressures and my gauge said all 4 were right at 34psi.
    I didn't get manuals with the truck when I bought it about 2.5 years ago so I can't look it up. After I turned the truck back on the warning light was off and has stayed off. Is this telling me a pressure monitor battery is going bad? It didn't seem like the pressures were low. What else could it be?
    Thanks!
  2. Oct 25, 2019 at 2:14 PM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    My 2006 is still running the original TPMS. When I have it below 30F it has same behavior. I believe it is battery/batteries. I did same check pressure, check spare, reset TPMS. I'm going to replace them all when I'm due for tires. Good luck. Please share the result.
  3. Oct 25, 2019 at 2:18 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    seanb06 likes this.
  4. Oct 25, 2019 at 3:57 PM
    photonashville
    photonashville Well-Known Member
    2006 Silver 4x4 long bed with Leer
    Don't our spares have the sensors too? I have to air up my spare every few years and the light goes off.
    Muddinfun likes this.
  5. Oct 25, 2019 at 4:03 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Yes yours might
  6. Oct 25, 2019 at 4:06 PM
    Muddinfun
    Muddinfun Well-Known Member
    Yep, that was 1 of my bargaining chips when I bought my '06 Taco from a car lot. The light was on and the tires were visibly low. I used their air to air up the 4 tires. The light was still on. "There's something wrong with the TPMS system. That's gonna cost money to fix." Found out a few days later that the spare has a sensor. Yep, spare was low. Aired it up and the light went out.
  7. Oct 25, 2019 at 5:15 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The TPMS sensor is only in the spare for a few model years. My 07 has one in the spare. But about 8-10 years is about as long as most batteries last. My sensors are still working in my 07 Tacoma, but the batteries died in the 09 Honda about a year ago. I'd advise buying some before you need new tires. Any tire store will install them free when you get tires mounted. If you try to replace them any other time it will cost you $10-$20 per tire to replace them.
  8. Oct 25, 2019 at 6:48 PM
    Geoff.in.nc
    Geoff
    Fayetteville NC
    Thanks folks. It didn't dawn on me that the spare might have a TPMS and I didn't check it
    Will try to do that this weekend. BTW I drove about 140 miles after I checked the 4 tires, and it never came back on.
