Low Tire Pressure Light wont turn off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Naterx, Jul 30, 2022.
  1. Jul 30, 2022 at 11:57 AM
    Naterx
    Naterx [OP] Well-Known Member
    Nathan
    2015 TRD Sport
    Bought my 2006 trd off road recently, and the tire pressure light wont turn off. The tires, including the spare are at the proper psi but the light wont turn off when i try to reset it. Did the sensor go bad? What can i do?
  2. Jul 30, 2022 at 12:24 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Does it blink first and then stay on solid?
  3. Jul 30, 2022 at 12:25 PM
    Naterx
    Nathan
    2015 TRD Sport
    It constantly blinks pretty fast. Then if i hold down the tire pressure reset button the blinking slows down for three blinks, and then resumes its normal speed. Never turns off...
  4. Jul 30, 2022 at 12:27 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Most likely 1 or more sensors have failed, most tire shops should have the tooling to test the sensors and replace and program new ones.
    Jimmyh and Naterx[QUOTED][OP] like this.
  5. Jul 30, 2022 at 3:38 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Sensors typically last 7-10 years. But some last longer. The ones in my 2007 were still working after 14 years when I proactively replaced them when I had my last set of tires mounted. New ones were $20 each on Amazon. I ordered new sensors beforehand and Discount Tire charged me nothing extra to install and program the new ones along with mounting the new tires. Most places will charge $10-$15 to install them if you're not getting new tires anyway.
    FYI, you'll need a 5th one for the spare on that model.
  6. Jul 30, 2022 at 4:55 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does it ever stop blinking?
  7. Jul 30, 2022 at 10:36 PM
    Fooburger
    Fooburger Well-Known Member
    Jim
    Southampton, PA
    2011 Tacoma sr5 access cab
    3” w/jba’s. LCE header w/intake spacer & hps cai tube
    I have no sensors in my tires and mine blinks then goes solid.
    Today while I was sound proofing the roof I found the tps control box attached to the roof.
    I unplugged it and removed the box, can’t believe the dam light is still on.
  8. Jul 30, 2022 at 11:22 PM
    TnShooter
    Deogee
    STOCK
    Mine does the same thing.
    Blinks then stays on. Been that way for years.
    You can get the light to go off if you search.
    There is a DIY out there. I think on this forum too.
  9. Jul 30, 2022 at 11:29 PM
    Fooburger
    Jim
    Southampton, PA
    Thanks man, yeah, was skimming thru one today where you pull out 2 wire pins….
  10. Jul 31, 2022 at 6:58 AM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    hate those damn things...i am old school and use a pressure guage !
    amyracecar and TACOMA2NDGEN like this.
  11. Jul 31, 2022 at 7:37 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    This is one of those ninny devices demanded by government "safety experts". IF a tire blows out like the old Ford Explorers being run on low pressure with defective Bridgestone tires (cost Ford a fortune) - it killed a lot of people out of pure ignorance. So the ninny device was Federally mandated - there's even a big fine if a pro shop deliberately deletes it. They are allowed to leave it in warning mode - just can't turn it off.
    My wife had one of those Explorers and we never had the problem - I check tires at every fuel stop and once a week on hers as general principle. Ford contacted her by recall letter and arranged to replace all of the Bridgestone tires.
    JGO likes this.
  12. Jul 31, 2022 at 9:26 AM
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    If memory serves me, Ford recommended lower pressures to ensure a 'soft and comfortable' ride.
  13. Jul 31, 2022 at 9:40 AM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Ford put the blame on Firestone when the reality was it was a bad vehicle design.
    "During the post-recall period, April 1, 2002 through December 31, 2007, there were 285 deaths in 232 reported, tire-related, Ford Explorer crashes recorded in the Fatality Analysis Reporting System (FARS). This total exceeded that for all other comparison utility vehicles combined, which accounted for 275 tire-related deaths during this period." https://www.safetyresearch.net/tire...=– Ford may have won the,to be the real loser.
    There were more rollover deaths in Explorers after the tire recall than before. We can all blame Ford and their high paid lawyers for that little annoying light.
    JGO likes this.
  14. Aug 7, 2022 at 6:42 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    My batteries died in mine. I just recently got new nittos and i told the tire shop to put regular valve stems in. And i put black tape over the sensor light in the dash. Fairly easy to remove cluster
    JGO likes this.
  15. Aug 7, 2022 at 7:10 AM
    shmn
    shmn Well-Known Member
    Pacific NW
    2007 Tacoma 2.7L 5sp
