Low tire pressure light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tenderheart116, Oct 3, 2011.
  1. Oct 3, 2011 at 10:15 AM
    Tenderheart116
    Tenderheart116 [OP] New Member
    Bruce
    Virginia
    07 TRD 4x4
    I hope I am not re-asking an old question, but I can't find a thread. I recently purchased a used 2007 (34k miles) Tacoma, and this weekend my low tire pressure light came on. I found one tire was a couple pounds low, so I filled it to spec and checked all the others. But the low tire pressure light will not go off. It has been two days and I have driven about 100 miles. Any ideas?
  2. Oct 3, 2011 at 10:16 AM
    98tacoma27
    Ben
    Not Beech Creek
    Check the spare? Hit the reset button (if you have one)? Read the manual? :p
  3. Oct 3, 2011 at 10:17 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    check your spare?
  4. Oct 3, 2011 at 10:24 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Check the spare and reset the light using the button under the steering wheel.
  5. Oct 3, 2011 at 10:31 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    DITTO
  6. Oct 4, 2011 at 1:42 PM
    Tenderheart116
    Bruce
    Virginia
    07 TRD 4x4
    Per all the great suggestions, I checked the spare, it was low so I filled it. Light still on. I found the reset button per the recommendations, and the problem is now solved. However, I have not found any mention od the reset button in my manual. hanks for all the help!
  7. Oct 4, 2011 at 1:59 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    TPMS is the abbreviation they use (I think)...
  8. Oct 4, 2011 at 2:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This ^^
    Tire Pressure Monitoring System
  9. Oct 4, 2011 at 3:08 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    My tpms cane on again this am I. I figured because of the tempature change. Stupid Alberta weather.
  10. Oct 4, 2011 at 3:23 PM
    OZ-T
    Peter North
    British Columbia
    Mine does that when it's really cold too
    Drop your pressure 5 or so psi below your operating pressure , set the system , then bring your tires up to pressure .
    The TPMS only detects a reduction in pressure , this will keep the light off for winter .
  11. Oct 4, 2011 at 6:54 PM
    jimiola
    jimiola Member
    07 prerunner
    anyone have trouble with their lug wench geting lugs off? I couldn't get the wrench to seat and it stripped out one of the nuts and had to get towed to the dealer and they couldn't get it off with the wrench either. Toyota is reimbursing for the tow :) I have 07 btw
  12. Oct 4, 2011 at 8:15 PM
    grapevine220
    grapevine220 ...and here we...GO....
    Grapevine, Arkansas
    09 Toyota Tacoma Silver Double Cab TRD 4x4
    Matching Tonneau cover, Raptor series 4" nerf bars, tinted front windows, weather tech digital floor mats, Leather seat covers, K&N filter element, OBX throttle body spacer, Wade bugshield, Wade in-channel vent visors, Recon Line of Fire rear LEDs, Bull bar, Redline Tuning hood struts, Reid's leather armrest mod
    I have went to Nitrogen in my tires instead of air. It is not as sensitive to temperature change as compressed air, that is one reason why planes have nitrogen in their tires:plane:
  13. Oct 4, 2011 at 8:24 PM
    aficianado
    back to bone stock.
    do a search.
    the lugs on our trucks are retarded. they are actually 20mm lugs with 1mm of dumbass chrome foil wrapped around them for the total 21mm. what happens is the wrap swells off the lugs and makes them a fat 21.5mm. a 22 fits, but is a poor substitute.
    i am gonna order new aftermarket lugs from wheelers as soon as i get off my ass.
  14. Oct 4, 2011 at 8:28 PM
    jw1983
    Alberta
    It warmed up this afternoon and it went off lol
  15. Oct 4, 2011 at 8:34 PM
    aficianado
    back to bone stock.
    my light always comes on when i am in the backwoods hunting. exactly the worst time for that light to come on. really rattles your security, being so far from any compressed air.
    i think it is because my truck is freezing it's ass off. and i run nitrogen in my tires.
  16. Oct 4, 2011 at 9:02 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I get the tmps light once in a while during cold mornings...seems it happens after the 4 tires warm up but the spare stays cold. Maybe that's why Toyota stopped putting a sensor in the spare?
  17. Oct 27, 2013 at 1:12 PM
    Brandoaz
    Brandoaz Active Member
    I have an 07 Tacoma with the TPMS that is on and wont reset using the reset button, it just flashes and then goes back to being solid.
    BUT, in reading this thread i see people suggest i check the spare.
    MY spare is on the truck, the wheel/tire that was on the truck in the bed of the truck with a shredded tire on it after a blow out.
    In just a bit i will take the shredded unit out of the truck, will it reset then?
    EDit:
    No it will not.
    Spare is in garage, tried to reset indicator, it starts to flash and continues and then goes solid again.
    Is this BECAUSE there is no spare?
    How does this system sense the low pressure and where are the sensors?
  18. Oct 27, 2013 at 8:07 PM
    aficianado
    back to bone stock.
    yes..the spare's sensor is missing. get the tire fixed and put it back "near" the truck.
  19. Oct 27, 2013 at 8:20 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    This ^^^^^
    David
  20. Dec 2, 2013 at 4:34 PM
    07toyotatacoma
    07toyotatacoma Member
    Stephen
    29 Palms California
    I recently put 4 new 285 75 16's on my tacoma and the TPMS light came on, I took the spare off the truck, and have nothing down there as of now... will this keep the dash light on?
    2007 toyota tacoma prerunner
