Low tires make truck look normal and rugged
Discussion in 'Wheels & Tires' started by Sundance Pro, Apr 8, 2018.
When the tires are low psi the truck do s not look as good
  1. Keep higher psi in tire
    4 vote(s)
    40.0%
  2. Add larger tires
    6 vote(s)
    60.0%
Multiple votes are allowed.
  1. Apr 8, 2018 at 9:34 PM
    Sundance Pro
    Sundance Pro [OP] New Member
    Criss
    2118 Toyota Tacoma TRD Pro
    Nice to meet all of you. I’m Sundance Pro. I just got my first TRD Pro Tacoma 2018, yesterday.when Was driving home from Los Angeles in my truck. I had to travel 360 miles to get it. Question I have: I don’t like th tires when they have low pressure. The dealer put in 31 pounds and it made the truck to low. As soon as I got home I Aired to tires to 44 psi. What does everyone else use.
    DustStorm4x4 likes this.
  2. Apr 8, 2018 at 10:25 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW... Personal choice, more air means rougher ride...I keep mine at 35 psi
  3. Apr 8, 2018 at 10:33 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    If you still have the factory tires just fill them to what the door sticker says. 44psi is probably the max lissted on the tire and not where I would run them normally.
  4. Apr 8, 2018 at 11:08 PM
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    Welcome to TW!:cheers: There's pros and cons to both, you just half decide what you want to deal with. Higher PSI you'll get better gas mileage, but the ride quality will suffer and the suspension needs to work harder. Lower PSI gas mileage will drop some, but ride quality will improve and the tiers share some of the suspension duties by helping to suck up some of the bumps. Just make sure you don't go beyond the recommended max cold PSI. Same with running too low of a PSI. There's other pros and cons, but that's the short of it.
  5. Apr 8, 2018 at 11:09 PM
    Lost In The Woods
    Eric
    Buckley, WA
    By the way, Larger tiers.... The answer is ALWAYS larger tiers.:D
  6. Apr 9, 2018 at 12:04 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    welcome.
    I think 44 on stock tires is really high. when they warm up it'll go beyond that.
  7. Apr 9, 2018 at 1:10 AM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    Welcome! :hattip:
  8. Apr 9, 2018 at 1:13 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Another thing worth mentioning is tire wear. With the pressure that high, you're going to wear out your tires in the center.
  9. Apr 9, 2018 at 1:19 AM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    First off, I don't understand your title thread. Low tires make truck look normal and rugged. What? Please explain what you mean by that.
    Second, what do you not like about 31 PSI? Hard to really say what you need when we don't know what the problem is.
    Exactly what tires are on the truck now?
  10. Apr 9, 2018 at 1:21 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    44 is way too high. Not sure about the 3rd gen, but my '15 Sport with 17's calls for 29
  11. Apr 9, 2018 at 1:31 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
