Low trans fluid
Discussion in 'Technical Chat' started by ckingfish, Jun 20, 2019.
  1. Jun 20, 2019 at 7:04 PM
    ckingfish
    ckingfish [OP] New Member
    Chad
    2017 trd dcor tacoma
    Thanks for the add. Found you because if a search of a problem i was having. Thanks for adding in communication.
    2017 dcor auto taco 16k .. Last week shifting from park to reverse heard a metal clunk. After that the truck would jolt when going park to reverse. I noticed would also not shift into 5th and 6th. Dealer said low a quart of trans fluid. Just saw thread and doing my part.
    TOMB likes this.
  2. Jun 21, 2019 at 5:35 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Welcome to the madness.
    We will help you spend your $$$$.
    Good thing it was checked out.
    Toyota is to cheap to actually have dipsticks.
    TOMB
