Lower Ball Joint advice needed.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fatherof2, Nov 14, 2015.
  1. Nov 14, 2015 at 1:39 PM
    Fatherof2
    Fatherof2 [OP] Well-Known Member
    Massachusetts
    2004 DC TRD
    Hi Gang,
    I had new tires installed on my truck today, and the guy at the shop showed me that I need a new lower ball joint on the drivers side. He wants 210.00 bucks to do it. (I'm guessing that he will use cheap parts............the shop is NTB.)
    I like to do stuff myself, so can anyone recommend a good place to buy what I need online? I want to go with good quality parts at a fair price.
    Last question.....I wont be able to do the job until next weekend. Is that a big deal? There is play in the joint, but its not horrible. The passenger side is just fine.
    Thanks All!
  2. Nov 14, 2015 at 2:38 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I would only go with OEM on such an important part. I haven't replaced one myself, but it looks pretty easy. If you are used to working on vehicles, go for it. Other than normal tools, you just need a ball-joint puller and a torque wrench.
  3. Nov 14, 2015 at 2:43 PM
    Madjik_Man
    Colorado Front Range
    Go with OEM lower ball joints.
    Camelback Toyota has them for $97 ea. Don't know what shipping is. For comparison I just paid $117 ea at the local dealership and that's with a 20% discount.
  4. Nov 14, 2015 at 2:45 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    If IIRC, Toyota had a recall on the ball joints a number of years ago. I'd check at the dealership before I did anything else and see of yours have been done. All they need is the V.I.N. to check.
    It may save you a few $$ if they haven't and Toyota picks up the tab due to the recall. Hope this helps.
  5. Nov 14, 2015 at 2:47 PM
    Madjik_Man
    Recall only applies to 01-04 Tacomas. Don't know the specifics of the OPs truck.
  6. Nov 14, 2015 at 3:07 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    They're not too hard to change out yourself. I used OEM. If you do a search, you can find hundreds of horrible pictures of peoples' Tacos after their lower ball joints failed while driving down the road. It's not pretty.
  7. Nov 14, 2015 at 3:18 PM
    Fatherof2
    Massachusetts
    2004 DC TRD
    Thanks for the input guys.
    My truck is an 04 DC TRD.
    I had it at the dealership awhile back to see if I qualified for a new frame. I didn't as mine was in good condition. I think the dealership was kind of bummed as they love the jobs that Toyota pays for.
    They didn't say anything about a recall on lower ball joints. I will check it out.
    Looks like an easy job based on the videos I watched on youtube.
    Thanks again!
  8. Nov 14, 2015 at 3:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    OEM all the way. And do both sides at the same time. Even if the other side isn't showing any signs of wear.
    IMO, LBJs should be a regular maintenance item, just like the water pump and timing belt on the v6. Every 90K. Don't wait for failure on this stuff.
    Speedytech7 likes this.
  9. Nov 15, 2015 at 2:15 AM
    Fatherof2
    Massachusetts
    2004 DC TRD
    I am at 140K with the original water pump!
    Should I replace it pronto?!
    Too big of a job for me......and it ain't cheap!
  10. Nov 15, 2015 at 3:00 AM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    The lower ball joint is only a few bolts and a few smacks with a hammer and it's off(Google shock and fall sus pension you dont need a pulcer to get the tiemail rod or the nall jpint loose)..you'll need a torque wrench to put it back on. Do the water pump when you do the timing belt next assuming it's the 3.4
  11. Nov 15, 2015 at 3:00 AM
    Rmodel65
    Jawja
    1996 Yota 4x4
    Viper Red paint
  12. Nov 15, 2015 at 4:48 AM
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    Lower ball joints are really easy to do. Don't need any special tools except torque wrench. BUT you do need some locktite on the threads. Red I believe. Definitely go with OEM.
  13. Nov 15, 2015 at 5:11 AM
    Fatherof2
    Massachusetts
    2004 DC TRD
    Thanks for the input guys!
    Love this forum!
    Love my Taco!
  14. Nov 15, 2015 at 7:28 AM
    Tinmann
    NorCal
    Use the blue lock tite, its much easier to loosen than the red.
  15. Nov 15, 2015 at 10:30 AM
    MrRiverMan
    WNC
    For sure. Red usually requires heat to get it undone, which would likely melt the boot on your ball joint. Since the LBJ has to come off for some other maintenance things like changing struts, you don't want to have to sacrifice it in order to take it off.
  16. Nov 15, 2015 at 3:18 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I used Moog when I did mine 3yrs ago but I also plan on cutting the IFS this winter. I would go OEM if you are in it for the long haul. A puller also helps, its like 12 bucks and a useful tool to have any way.
    As for red locktite: I have never had to use heat to get that off, maybe a breaker bar and I would classify myself as a pussy.
  17. Nov 15, 2015 at 5:59 PM
    Fatherof2
    Massachusetts
    2004 DC TRD
    Where is a good place to get a LBJ tool?
  18. Nov 15, 2015 at 6:09 PM
    Rmodel65
    Jawja
    1996 Yota 4x4
    Viper Red paint
    You don't any tools other than the torque wrench...you hit the area where the stud sticks through with a hammer read the shock and fall article I posted above....
  19. Nov 15, 2015 at 7:17 PM
    slander
    Hickory, NC
    I bought it from autozone, its the big ushaped puller with the threaded rod. Yea you can beat it off (ha) with a hammer, but the pullers dirt cheap and you can zap that bj off in 2bursts of the impact.
  20. Nov 15, 2015 at 7:52 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    I would say go with the NAPA Chassis line of ball joints. They have an improved design that works better than any moog or raybestos aftermarket ball joint out there. supposed to better than OEM even.
