Lower Ball Joint Bolts - Lesson Learned
Discussion in '1st Gen. Tacomas (1995-2004)' started by Enoxon 9598, May 18, 2016.
  1. May 18, 2016 at 10:48 AM
    Enoxon 9598
    Enoxon 9598 [OP] Member
    Jeff
    Great Falls MT
    '98 SR5 Taco, '95 Taco
    ARB Bumper after market suspension, motor swap, sliders, custom roll cage, soft top
    I replaced Lower ball joints on my '98 4x4 Tacoma about 8 months ago. Didnt have a torque wrench at the time - went for "darntight".... A couple months ago, I installed Bilstein 5100's, AAL's, pinion bushings and had it aligned - so far so good.
    I rotated my tires last night and noticed a LOT of play on driver's side front tire. Did some wiggling and discovered that my LBJ was lose and missing a bolt. Being that i have since purchased a torque wrench, I went about tightening down the other three bolts and found a 4th to replace the missing one. Here's where I started to run into issues (other than the spine-tingling feeling of what could have happened had I not caught it when I dido_O).
    First of all - without the factory service manual - finding that torque rating wasnt easy. Looking like 45-60 some ftlbs. Knowing that my idea of "darntight" was way in the hell higher than that, its obvious that I over tightened them.
    Mess-up #2: Everything I have read says that lock tight is required.
    Mess-up #3: As I learned with u-bolts on the AAL's, I should have bought new bolts rather than re-use the factory (I assume) bolts.
    Now for the fun of tapping new threads as the missing bolt apparently took the threads with it.
    Has anyone used a "thread chaser"? I would rather not drill it out and go for a bigger size. Thanks in advance.
  2. May 18, 2016 at 11:35 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Thread insert of your choice is what I would do .
    Those are M10x1.25 are they not??
  3. May 18, 2016 at 11:39 AM
    Enoxon 9598
    Jeff
    Great Falls MT
    They are. Just purchased a tap for that size. Hoping enough threads are intact to handle the torque. I looked at thread inserts while at the tool specialty store. I did a helicoil for a blown out spark plug on my 95 3.4 and that was a nightmare. Worked tho. I think there is plenty of metal to jump up to a 12mm. Would thread insert be a better choice?
  4. May 18, 2016 at 11:44 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    It is what I would use but that is me.
    Will a 12mm bolt 17mm head cause clearance problems
    Without being under a truck I have no idea
  5. May 18, 2016 at 12:08 PM
    Enoxon 9598
    Jeff
    Great Falls MT
    Hadn't considered the head not clearing. I'll look into that when I'm under it this evening. It is one if the two closest to the dust cover, however.
    Hopefully I won't have to cross that bridge...
  6. May 19, 2016 at 5:08 AM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    Would a 1/4'' longer bolt grab a few more threads maybe?
  7. May 19, 2016 at 6:02 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Blue loctite the LBJ bolts.
    Digiratus likes this.
  8. May 19, 2016 at 10:10 AM
    Enoxon 9598
    Jeff
    Great Falls MT
    Re-tapped both outer holes and managed to get the bolts torqued to proper settings. Lots of blue loctite. Dodged a bullet here! Might have to take a picture of the bent and mostly stripped out bolt from the outer side... One for the wall of shame for sure!
  9. May 19, 2016 at 12:45 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Funny I never seize those bolts after having to remove the steering knuckles on both sides to drill those bolts out.
    Talk about a lower ball joint project . I should have just bought new steering knuckles it would have been easier.
    I learned my lesson No long Holiday weekend projects.
    HelenaTDI likes this.
  10. May 19, 2016 at 2:05 PM
    Enoxon 9598
    Jeff
    Great Falls MT
    Definitely enough room.
  11. May 19, 2016 at 2:44 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I personally use red. Holds tighter than blue, but can still be removed just fine. No need for heat.
    Also make sure you clean the threads of grease and dirt when you reinstall. I usually just spray brake cleaner in the holes liberally.
  12. May 19, 2016 at 2:54 PM
    Enoxon 9598
    Jeff
    Great Falls MT
    I used penetrating oil when re-tapping the threads so had to clean with break cleaner anyway. Worked well on the loads of road grime built up on them too.
