Lower Ball Joint Boot is Tore
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Mega, Apr 5, 2010.
  1. Apr 5, 2010 at 12:31 PM
    The Mega
    The Mega [OP] Get Routy
    Phoenix
    06 4X4 Speedway Blue
    Custom Retrofit Headlights, TRD CAI, Magnaflow Exhaust, Demello Offroad Sliders, Icon Coilovers w/ reservoirs, Allpro Rear Leaf Pack w/Fox reservoirs, Ubolt Flip Kit, Bed Mounted Spare, Total Chaos UCA, Steal Brake Lines All Around, Viper Remote Start, Custom Emblem Work, Black Tail Lights, and Flashlight Mod, Devil Emblem, Color Matched Interior, Demello Front Bumper, Onboard Air, Courtesy LED Lights (Interior and Exterior), Secondary Fuse Block, Hood Struts, Engine Bay Lights
    So on the passanger side, the lower ball joint boot has a tear in it, which would be the ball joing on the lower control arm. Its not a big tear but there is grease that has come out. This happened while I had my truck at Glamis. I have a couple question. First, is this something I should be extremely worried about and fixed immediately or is this something that is not a huge concern and will be okay for a month or so? Second, to fix this do I have to replace the ball joint completely or can you just replace the boot? Third, I do have coilovers, should I try and take it to the dealership under warranty or is it not even worth my time? Any advice will be greatly appreciated!!:D
  2. Apr 5, 2010 at 12:34 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    You can buy and replace just the boots, assuming there isn't a problem with the CV that caused the boot to tear.
    Don't know about your other two questions:)
  3. Apr 5, 2010 at 1:08 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    As far as I know (99% certain) the lower ball joint boots are not available as a separate item. Upper boots were available in the past but not lowers. Also, the ball joint itself is not available from Toyota as a separate item either - you have to buy the complete lower control arm. You'll also likely need new alignment cams and bolts, as well as new lower control arm bushings. Expect it to be very $$$. The aftermarket may have a replacement BJ for the 2005+ Tacoma's now - but none were available when I had mine replaced (1.5 years ago).
    This doesn't need to be replaced until the lower ball joint develops play and begins to fail. This may take as little as a week, or I had this happen before and got 1.5 years out of it. The rate of wear depends on the amount of grit/water that contacts the joint itself. Since we don't know how large the tear is or the rate of grease leakage this really is only a guess. If you were to purchase one of those grease gun adapters that looks like a hypodermic needle and grease you BJ every month or so that will prolong its life.
    You can try your luck with warranty but I doubt they will cover a ripped boot. A boot usually rips because something tore it rather than a manufacturing defect.
    Keep us updated...
  4. Feb 25, 2013 at 12:58 PM
    bruth
    bruth Well-Known Member
    Brian
    Alamo ca
    2000 access cab 4x4 Tacoma
    Total chaos is currently shipping
    Mine was torn for about 4 months on my driver side ... Went wheeling... Now it is so load from dirt in it tht it sounds like a banshee while I drive around! Soo I'm going to buy a BJ press and swap it with one that has a zerk fitting!
