Lower ball joint failure
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shortman5, Oct 16, 2016.
  1. Oct 16, 2016 at 10:01 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    Most all of the failures I've seen...
    are due to the retaining bolts loosening or breaking.
    Tho' ball joints wear out and can create excessive slop...
    thereby effecting the alignment specifications/requirements
    Loose or worn BJ's gives most folk a reason for their replacement.
    Ball joints generally don't separate unless an impact were involved
    or the retaining bolts came loose and allowed for excessive movement.
    In other words... inspect those ball joint bolts on occasion
    and be sure they are still tight.
    Locktite does well for keeping the BJ bolts secure.
  2. Oct 16, 2016 at 10:04 PM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    I got my fronts used, and rebuilt them. Huuuuge savings there. Jumped on a group buy from @Downsouth Motorsports for my rears. The hit to the wallet is rough, but worth it.
  3. Oct 16, 2016 at 10:04 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Kings bro:headbang:
  4. Oct 16, 2016 at 10:06 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Is that the solo motorsports relocation?
    Was looking at that one but was hearing at tire stuff it hits the shock body?
    Unless you run a skinny tire or spacer
  5. Oct 16, 2016 at 10:09 PM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Yep, it's the Solo kit. With 2.0's and a small spacer you wouldn't hit. But I have 2.5's and no spacer, so it rubs at full stuff. Not bad, but enough to leave small black marks.
    snowboard704[QUOTED] likes this.
  6. Oct 16, 2016 at 10:12 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea I wanted the 2.5s also but kept hearing about the rubbing issue, just went with the bamf relocation
  7. Oct 16, 2016 at 11:27 PM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Doesnt BAMF recommend 2.0's as well? I know total chaos does also.
    snowboard704 likes this.
  8. Oct 17, 2016 at 7:03 AM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    No I run 2.5s no problems:notsure:
  9. Oct 17, 2016 at 9:19 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    True, the more I read into LBJ failure the more I'm seeing cases where people just had new ones installed, but they or the techs didn't torque them down properly or didn't use lock-tite on the bolts and they ended up failing. Definitely worth double checking if someone else did the work.
  10. Oct 18, 2016 at 7:17 AM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Probably the most important bolts on the truck. The weight of the truck hangs from those 4 bolt heads and all of the steering torque is transferred through them.
    I plan to check mine next time i have the wheels off. I torqued them and used blue locktite.
  11. Oct 18, 2016 at 10:52 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    What size tire you running and what BS wheels? Also what bumps are you running? I see an aluminum spacer added to the top stop right?
  12. Oct 18, 2016 at 1:05 PM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Stock bumps. We added the spacer so that it bumps correctly until I can afford some 2" cans from King.
    Running 256/75r16 KO2's on SCS F5's. I think they're the 3.5" bs.
  13. Oct 20, 2016 at 8:40 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    I just noticed i have play in mine. picked up a ac delco replacement as they are made in japan. so hopefully its better then some of the cheaper crap lol
  14. Apr 13, 2018 at 4:28 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    I replaced mine last year (about 15k ago) and they are already bad according to the tech at a buddies shop. He even send me a video and they look toast by the amount of play. How could genuine toyota lbjs only last 15k?! Im shocked....
  15. Apr 13, 2018 at 4:55 PM
    #35
    eon_blue
    Azusa, CA
    damn that sucks dude, I got new OEM LBJs put in about 20k miles ago...maybe I should give them a check
  16. Apr 13, 2018 at 5:42 PM
    #36
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea I would definitely give them a check. Ill tag you where I posted the video also. After I threw them on I figured they were going to be good for at least about 100k miles....:anonymous: Guess not
    eon_blue[QUOTED] likes this.
  17. Apr 14, 2018 at 11:30 AM
    #37
    Matt83
    Matt83 Well-Known Member
    If your angles are extreme it can lead to shorter life as well.
  18. Apr 14, 2018 at 12:31 PM
    #38
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Lbj angles?
  19. Apr 14, 2018 at 12:34 PM
    #39
    Thurman Merman
    Thurman Merman Well-Known Member
    Denver, CO
    It's a 50-J safety recall. I just had mine done a few weeks ago...12 years late lol.
    If you have a dealership, call them up and ask them to check your vin against records for the 50J recall that was issued in 2005. If it hasn't been performed, then you get new LBJs. They may not do it if you've got a lot of aftermarket shit going on down there though.
  20. Apr 14, 2018 at 12:36 PM
    #40
    Thurman Merman
    Denver, CO
    Well, you're lifted with gigantic tires and probably do a fair bit of off-roading. That's adding a lot of stress to stock LBJs. Still though, 15-20k is pretty low even for the added abuse.
