Lower ball joint help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco0416, Sep 5, 2025.
  1. Sep 5, 2025 at 1:01 PM
    Taco0416
    Taco0416 [OP] Well-Known Member
    1996 Toyota Tacoma
    I’m guessing the lower ball joint on my 1996 Tacoma had been replaced some time in the past 30 years but just in case I’m planning on just doing it as a preventative measure.
    So my question is what are a good price for a set? On yota1 they are going for $200 each so $400 total. I trust yota1 but it’s crazy how much more they are there vs everywhere else. I have heard you don’t cheap out on this one part and go with OEM lower ball joints and I respect that, just hard finding sets that meets or exceeds OEM specs for $100-300. I even find sets that meet and exceed OEM specs with a 3 year warranty that are $55.
    So any advice would be super appreciated
  2. Sep 5, 2025 at 1:08 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Order the LBJ TSB kit: 04005-03235
    https://toyotaparts.ourismantoyotao...Nna03nkQX2F6CvBRjhYGio504Jc5kL6PtKRkVAesINKid
    Only includes left and right LBJs, no hardware, but its way cheaper this way.
    And 8 bolts: 90119-10933 (These are the 37 ft lb bolts Do not torque to 59 ft lbs)
    https://toyotaparts.ourismantoyotao...jgcXNoOK7LAY5ZwGi0zv9xWdThCrYxOCd_KO59onYIflp
    Might need to run to Harbor freight and grab an assortment of 500 cotter pins for $5 if you don't already have those on hand as well.
    Should be out the door around $200.
  3. Sep 5, 2025 at 1:09 PM
    oldgreg
    oldgreg Well-Known Member
    Greg
    2001 2.7 reg cab 4x4
    Don’t bother looking at “specs”, get actual OEM Toyota-branded LBJs. The consensus is that they hold up the longest.
    Check Toyota dealer sites for the baseline price, then find some dealer that’s doing a discount.
    Avoid eBay and Amazon.
    Pbfender15 likes this.
  4. Sep 5, 2025 at 1:14 PM
    Red_03Taco
    Red_03Taco @ the Taco Shop
    Jerad
    Yavapai County, AZ
    2003 Tacoma Xtra Cab 4WD
    Eaton E-locker (rear), Alcan Leafs, Toytec 2.0s (rear), Icon 2.5s (front)
    Right Lower Ball Joint:
    43330-39815
    https://toyotaparts.ourismantoyotaofrichmond.com/oem-parts/toyota-suspension-ball-joint-right-front-lower-4333039815?c=bD05Jm49U2VhcmNoIFJlc3VsdHMmYT10b3lvdGEmbz10YWNvbWEmeT0xOTk2JnQ9c3I1JmU9My00bC12Ni1nYXM=
    Left Lower Ball Joint:
    43340-39585
    https://toyotaparts.ourismantoyotaofrichmond.com/oem-parts/toyota-suspension-ball-joint-left-front-lower-4334039585?c=bD01Jm49U2VhcmNoIFJlc3VsdHMmYT10b3lvdGEmbz10YWNvbWEmeT0xOTk2JnQ9c3I1JmU9My00bC12Ni1nYXM=
    Ourisman Toyota has them listed for around $132 each. Either order from them, or go to your local parts deal and show them Ourisman's advertised price and request that they price match.
    EDIT: disregard the part #'s above and order what @time623 specified. Still suggest pricing them on Ourisman's website and then requesting local dealer price match though
    time623 likes this.
