Lower Ball Joint maintenance question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bend_corners, Jul 6, 2019.
  1. Jul 9, 2019 at 12:48 PM
    #41
    eon_blue
    Azusa, CA
    If you put your VIN into this website https://partsouq.com it'll tell you the part number for everything on your vehicle
  2. Jul 9, 2019 at 1:09 PM
    #42
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    For anything that's not specifically listed in the regular maintenance schedule, assume it is a lifetime part and replace ONLY as needed. If it ain't broke, don't fix it. Or do, I'm not your dad.
    You seem to be spending a lot of brain power on your rope hooks. Those cost like $5. If it's really bothering you, just replace them and stop thinking (and posting) about it.
  3. Jul 9, 2019 at 1:10 PM
    #43
    eon_blue
    Azusa, CA
  4. Jul 9, 2019 at 1:10 PM
    #44
    jbrandt
    Justin
    :devil:
    GQ7227 and eon_blue[QUOTED] like this.
  5. Jul 9, 2019 at 1:13 PM
    #45
    jbrandt
    Justin
    see edit. May or may not help...
    eon_blue[QUOTED] likes this.
  6. Jul 9, 2019 at 1:46 PM
    #46
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    To the original poster, leaking means grease is coming out, dirt is going in, and will wear out the ball/socket more quickly. Check if any play. If no play, drive it till you can get it done. Ball joints don't snap. The ball/socket wear out and come apart. Nothing breaks. Age has nothing to do with it. A sealed old joint with no play is just as good as brand new joint. A worn joint will show in tire wear and alignment long before its dangerous. For those that don't pay attention their vehicle, do what everyone else says and replace it as soon as it looks wet.:rolleyes:
    Bend_corners[OP] and GQ7227 like this.
  7. Jul 9, 2019 at 1:56 PM
    #47
    jbrandt
    Justin
    This goes back the idea that most BJ failures are more likely related to lack of maintenance (i.e. ignoring warning signs) than anything else. It likely just boils down to "you just didn't notice your boots had been leaking grease the last 40,000 miles"
  8. Jul 9, 2019 at 6:37 PM
    #48
    Jimmyrace
    Jimmyrace Well-Known Member
    JR
    Louisville, KY
    Betty '03 Taco MTM Xtra-cab DLX 5VZFE
    OME struts / springs / leaf pkg :: SPC upper A ::
    Lol - just did mine (pretty sure original) at ~215K
  9. Jul 10, 2019 at 7:59 AM
    #49
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    Nothing like a LBJ thread. :popcorn:... Seriously though leaking grease from a sealed suspension component is not good. If grease got out then road grime got in. Replace them.
    frenchee and jbrandt like this.
  10. Jul 10, 2019 at 9:34 AM
    #50
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    lol crazy. Thats awesome.
    I know people will come on here and say 200k 215k etc. I know one guy on here preaches about not replacing until 200K.
    100K is recommended. Personal choice. Not gonna risk my truck for couple hundred bucks every 100k lol.
  11. Jul 10, 2019 at 9:44 AM
    #51
    SouthernYoder
    SouthernYoder If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    Man the problem I have with these trucks is just those ball joints. Knowing that mine have 8k miles on them and lightly wheeled, oem parts only, and now My passenger side is leaking? I just don’t understand why that would be the case when everyone harps so high and mighty about them. Sucks man. Hey, upside is that I’ll wipe the grease off and swap them out when I want to, since it’s paid off and all
    :jerkoff:
    Jimmyrace and cruiserguy like this.
  12. Jul 10, 2019 at 11:35 AM
    #52
    STOBLES
    STOBLES Member
    Steven
    Long Beach, CA
    2001 Tacoma DC 2wd
    Total newbie here :anonymous: Long story short, I'm running stock LBJ's @ 260k+ :bananadead:. I got OEM replacements ready to put on but I'm confused as hell about the part# for LBJ bolts since mine didn't come with any. I've checked partsouq.com and it looks like theres two different bolts???
    9010510505 and 9011910933
    I've read somewhere about two bolts being longer than the other, is that what this is? Anyways, have you guys ordered both bolts or 4 of 1 type?
    Any help is muuuch appreciated.
    eimkeith and Jimmyrace like this.
  13. Jul 12, 2019 at 6:54 PM
    #53
    Jimmyrace
    JR
    Louisville, KY
    I don't know anything about this 'one longer than the other', but the part number for the bolts that I got from the parts counter at the dealer says it is the latter of the two you gave - replace all 8 (4/ea.)
    STOBLES[QUOTED] likes this.
  14. Jul 12, 2019 at 6:57 PM
    #54
    eon_blue
    Azusa, CA
    I got mine from toyotapartsdeal.com (lbjs and bolts)...all 8 bolts are the same size at least on my truck. The ones that came off and the ones that went on.
    GQ7227, STOBLES[QUOTED] and Jimmyrace like this.
  15. Jul 12, 2019 at 7:00 PM
    #55
    Kwikvette
    Fresno County
    4 run, 2 don't
    GQ7227 and STOBLES like this.
  16. Jul 13, 2019 at 6:56 AM
    #56
    eimkeith
    eimkeith Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
    The outer 2 bolts could be longer than the inner 2 to take advantage of the additional thread engagement of the blind holes in the LBJ.
  17. Jul 15, 2019 at 7:57 AM
    #57
    STOBLES
    STOBLES Member
    Steven
    Long Beach, CA
    2001 Tacoma DC 2wd
    Thanks for all the input guys :thumbsup: I plan on comparing the new bolts with the old ones before putting them on. I could post some pics when I get the job done.
  18. Jul 15, 2019 at 1:04 PM
    #58
    Louie2001
    Louie2001 Well-Known Member
    Louie
    Dallas, Texas
    2001 Tacoma TRD
    Front Fox 2.0 Coil-Over Shocks Rear Fox 2.0 Performance IFP Shocks FN Wheels Five Star -25mm Offset Cooper Discoverer STT Pro's 285/75R16
    Where do you check to see if there is a recall?
  19. Jul 15, 2019 at 1:12 PM
    #59
    eon_blue
    Azusa, CA
    Plug your VIN into this website and see if anything comes up
    https://www.toyota.com/recall
    Or call your local service dept, but I'd rather search myself. Safety recalls never expire so if your truck has a recall from 2004 it will still be valid today.
    I guess the only thing that would prevent them from doing it is if the part is no longer made, but as for the lower ball joints they most certainly still are.
    GQ7227 likes this.
  20. Jul 15, 2019 at 2:43 PM
    #60
    kyleschoen
    kyleschoen Well-Known Member
    Why do so many people think that the balljoints should be replaced on an interval? The maintenance schedule says to check them frequently, not replace them. Furthermore, the FSM provides a procedure and spec to test the LBJs. IMHO, you're wasting money by replacing them just because "it's been XX,XXX miles". I really dislike the parts shotgun approach.
    My truck is at 185K, driver side had 0.005" of play, passenger side about 0.007" where the FSM tolerance is 0.020":
    GQ7227 likes this.
