Lower ball joint replacement for the 1st time
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scouterdad, Jul 22, 2020.
  1. Jul 22, 2020 at 9:59 PM
    Scouterdad
    Scouterdad [OP] Well-Known Member
    Sandpoint ID
    1996 white Tacoma
    Hey gang, this is my first time posting a thread so bare with me.
    I'm collecting data to do my lower ball joints. The previous owner never had them done so they are still riveted in. If some of you more experienced fellas can walk me through the procedure or direct me to thread that does I would be most grateful. :thumbsup:
    GQ7227 likes this.
  2. Jul 22, 2020 at 10:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ask all the questions you want!
    We're all here to help; first off here are the part numbers -
    43340-39585 - Left side(driver side)
    43330-39815 - Right side(pass side)
    The rest is pretty easy; since you'll be doing them for the first time, make sure you soak the bolts in penetrating oil. That and expect the ball joint to scare ya when it 'pops' out of place.
    B.rad31 and eherlihy like this.
  3. Jul 22, 2020 at 10:04 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Could you share a picture? I believe the ball joint itself has always been bolted on and the rivets I think you're referring to are the ones one the LCA that hold in the tapered mount for the ball joint
  4. Jul 22, 2020 at 10:07 PM
    Madjik_Man
    Colorado Front Range
  5. Jul 22, 2020 at 10:12 PM
    Scouterdad
    Sandpoint ID
    1996 white Tacoma
    Yes that is correct, a friend of mine had mentioned it and while he is not a Toyota guy he is a talented mechanic .
    so I crawled under there earlier and sure enough three big fat rivets . I need to remove those right ?
  6. Jul 22, 2020 at 10:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    What rivets do you keep talking about?
    It's just 4 bolts and the nut that holds the ball joint to the lower control arm.
    Just take your time and don't rush anything as some have broken their bolts that hold the ball joint in place. Sucks when you have to remove your spindle to get it all apart.
  7. Jul 22, 2020 at 10:24 PM
    Abeyancer
    Jimmie
    PNW
    No those 3 rivets are apart of the lower control arm. The lower ball joint is bolted to the spindle directly above that
    Kwikvette likes this.
  8. Jul 22, 2020 at 10:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ah now I know what he's talking about :rofl:
    I was about to say "there are no rivets on the ball joint at all anywhere"
    Abeyancer[QUOTED] likes this.
  9. Jul 22, 2020 at 10:28 PM
    Scouterdad
    Sandpoint ID
    1996 white Tacoma
    Oh ok ! I see It looked like the balljoint was part of that lower assembly
    that is totally easier than what I thought . See you guys are awesome ! :headbang:
    taco03Trd likes this.
  10. Jul 22, 2020 at 10:29 PM
    Scouterdad
    Sandpoint ID
    1996 white Tacoma
    Yes that video was very helpful thank you !
  11. Jul 22, 2020 at 10:31 PM
    Abeyancer
    Jimmie
    PNW
    Don't hesitate to ask whatever questions you have! I'm sure they'll always be someone here that made that mistake already :rofl:
    I knew instantly what you were talking about because I had a mid 80s VW that had the balljoints riveted in place. First ball joints I ever changed in my life :eek: and I was so damn confused.
    haha everything I've worked on since then has had the balljoints bolted in place :thumbsup:
  12. Jul 22, 2020 at 10:44 PM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    I call my local steelership to check for recall and bam got then replace under a recall wont hurt to look into imo
  13. Jul 23, 2020 at 5:26 PM
    joe25rs
    joe25rs Well-Known Member
    Joe
    Mrr’land
    2004 Black TRD
    The recall campaign is still active?
  14. Jul 23, 2020 at 5:53 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    Did this job two weekends ago, it's not too difficult. If your tie rods or ball joints won't separate with hammering like the Low Range video, you'll want to use a Pitman puller. Also recommend picking up 8 new bolts for the LBJs (90119-10933).
    TWJLee and GQ7227 like this.
  15. Jul 23, 2020 at 6:12 PM
    taco03Trd
    Carlos
    Riverside ca
    Just call the dealer with your bin they can tell you if ur truck still meets the recall .
  16. Jul 23, 2020 at 6:25 PM
    Scouterdad
    Sandpoint ID
    1996 white Tacoma
    Yes, I'm a novice when it comes to mechanics . I went the other direction in automotive, autobody.
    So, do I just ring up my nearest local Yota dealer and hit em up for LBJ replacement ?
    GQ7227 likes this.
  17. Jul 23, 2020 at 6:28 PM
    taco03Trd
    Carlos
    Riverside ca
    That’s what I did an got lucky I guess end up being a free recall replacement LBJ ‘s
  18. Jul 23, 2020 at 6:33 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    I have rivets I think still
  19. Jul 23, 2020 at 6:35 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    I need minor autobody paintwork specialty
    How much?
  20. Jul 23, 2020 at 6:36 PM
    Scouterdad
    Sandpoint ID
    1996 white Tacoma
    Sounds good, I really appreciate everyone's input. Next time you guys are up here in North Id. lets have a Taco Thursday meet ! :mudding:
