Lower Ball Joint Replacement Interval
Discussion in '1st Gen. Tacomas (1995-2004)' started by bwise, Apr 8, 2025.
  1. Apr 8, 2025 at 3:39 PM
    bwise
    bwise [OP] Well-Known Member
    How often does everyone replace these?
  2. Apr 8, 2025 at 4:04 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Everyone has their own routine and there isn’t a set interval dictated by Toyota to replace that I’m aware of but they do recommend (like other components) a routine check. Process is the same as a third gen 4Runner, video for reference:
    https://youtu.be/sp-D0EtX2gU
  3. Apr 8, 2025 at 4:18 PM
    02hilux
    Planet: EARTH
    I got rid of mine…. Permanently
    Kwikvette likes this.
  4. Apr 8, 2025 at 4:29 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    Depends how and how much you use your truck. Routine check up as mentioned above and youll be all set
  5. Apr 9, 2025 at 5:39 PM
    acs118
    acs118 Well-Known Member
    Pittsburgh, PA
    2002 4WD V6 TRD Tacoma
    Originals replaced around 50k. Just replaced with OEM at about 200k. Were still in pretty good shape but replaced out of caution.
  6. Apr 10, 2025 at 2:32 PM
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    I'm going replace mine with the timing belt at 90k miles. I'll inspect at tire rotations.
  7. Apr 10, 2025 at 4:11 PM
    bwise
    Thanks all! Will inspect with every oil change/rotation using the video above
