Lower Ball Joint Replacement Questions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RacerP, Jun 10, 2012.
  1. Jun 10, 2012 at 12:25 PM
    RacerP
    RacerP [OP] Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    Even though I just got new lower ball joints with my frame replacement they are both completely dry and loose as hell.
    So replacing them with Moog greasable versions.
    2 questions:
    Do I need to keep that rectangular rubber boot on there that is held on with the 4 bolts??
    Ever since replacing my CV's I have found those 4 bolts that hold the ball joint to the spindle never stay torqued?? Even with thread locker. Why not use long bolts and put a lock washer and nut on the top??
  2. Jun 10, 2012 at 2:25 PM
    RacerP
    Chicago
    2003 4x4
    Well I discovered at least one of my bolts is stripped and won't tighten...
    Now What??
    Find a replacement spindle? Chase the threads? Gotta remove the whole spindle for that job anyhow?
  3. Jun 10, 2012 at 3:14 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    If you have one thats stripped, along with the loosening of others (keep coming loose) You probably oughtta take them all out & chase the threads or re tap w/new hardware...
  4. Jun 10, 2012 at 4:02 PM
    RacerP
    Chicago
    2003 4x4
    I figured exactly the same...
    I might just look for a set of spindles at a yard see if they are any better than mine...for roughly $50/each not worth all the work.
  5. Jun 10, 2012 at 4:54 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yeah, if you can get some out of wrecking yard for cheap I'd do the same thing, good luck ..:thumbsup:
  6. Jun 10, 2012 at 5:33 PM
    RacerP
    Chicago
    2003 4x4
    Now to figure out how similar Tacoma, Tundra, 4Runner, and Sequoia spindles are?
    Anyone have any idea if they are all direct replacements?
  7. Jun 11, 2012 at 3:37 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    I would call and ask the toyota junkyards like yotayard.com.
    It seems like tacomas don't just go to regular junkyards. There are many specialty yards that buy them.
  8. Jun 11, 2012 at 5:45 PM
    RacerP
    Chicago
    2003 4x4
    Haha, if I were someplace remotely close to them...Got any idea what a spindle and hub weighs?? Each has to be close to 40lbs!
  9. Jun 11, 2012 at 6:02 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    I had one of my LBJ bolts fall out. It turns out the threads in the spindle for that bolt was stripped. I ordered a helicoil kit from McMaster-Carr, installed and all is fine now. I thought about a nut on top, but it seemed too close to the outer axle boot, I was concerned about contact during active travel, so decided against it.
  10. Jun 11, 2012 at 9:04 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Keep an eye on that helicoil
  11. Jun 11, 2012 at 9:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I had both of mine off earlier that year to have the upper bjs pressed out and new ones pressed in. I think 40# is too high, more like 20# each with bearing hub and dist shield attached.
    I have seen this done. It makes the most sense and is not all that hard or expensive. The hard part is in getting the spindle/knuckle off and you have to do that no matter what.
  12. Jun 12, 2012 at 6:55 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    If you do get spindles try to get ones that have the ABS sensors still in them (if they're from a junkyard). I put new spindles on my truck and had to buy new sensors at about $170 apiece because the old ones were so frozen into my old spindles.
