Lower ball joint
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ahkouchi, Mar 20, 2021.
  1. Mar 20, 2021 at 5:09 AM
    ahkouchi
    ahkouchi [OP] Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    Anyone know the part number for the oem 3rd gen lower ball joint? I can only find the entire lower control arm and not the lower ball joint
  2. Mar 20, 2021 at 5:24 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    It’s easier on our trucks and cheaper to buy the whole LCA
  3. Mar 20, 2021 at 5:29 AM
    ahkouchi
    Andrew
    Big Island Hawaii
    Ahh. Thanks for the quick response.
    Ya problem is shipping to where I live cost almost as much as the control arm online. Going to my local toyota is almost 600 per side as well. Normally I change the ball joint only on my other trucks so I figured I'd ask if anyone knew anything or had any trouble with after market ones like moog ect
  4. Mar 20, 2021 at 5:53 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    OEM 43330-09510
    SR-71A, mcharfauros and T-yoda like this.
  5. Mar 20, 2021 at 6:02 AM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    I click on this and it comes up as if I wanna dial this phone number o_O
  6. Mar 20, 2021 at 6:57 AM
    Jowett
    Brian
    North Adams, MA
    Lol, yeah, just a part number, not a link. Copy the number and run a search.
  7. Mar 20, 2021 at 7:02 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Comes up as hilux part
  8. Mar 20, 2021 at 7:30 AM
    Jowett
    Brian
    North Adams, MA
    Everything points to it being the same.
    mcharfauros likes this.
  9. Mar 20, 2021 at 7:51 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    What symptoms do you have? I have a clunk type of noise on my driver side when turning right that I am having trouble chasing down.
  10. Mar 20, 2021 at 8:28 AM
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    I got it ;)
  11. Mar 20, 2021 at 1:05 PM
    ahkouchi
    Andrew
    Big Island Hawaii
    No real symptoms yet. Just getting ready because I have almost 100k miles. So I figured start doing research for parts while everything is still good and I'm not panicking later when it does start to fail.
    I also have a clunk when turning full right sometimes, normally over speed bumps ect. I kinda Narrowed it down to my driver front control arm bushing. Seems like it almost binds a little when full turn
  12. Mar 28, 2021 at 7:32 AM
    ahkouchi
    Andrew
    Big Island Hawaii
    You positive it's this part number? Just making sure so I don't end up ordering it and getting stuck with a non usable part lol
  13. Mar 28, 2021 at 8:30 AM
    Jowett
    Brian
    North Adams, MA
    How about this, I'll put my money where my mouth is. If they don't fit, I'll pay you for them.
  14. Mar 28, 2021 at 9:22 AM
    ahkouchi
    Andrew
    Big Island Hawaii
    Lol appreciate it man. Just figured I'd ask to make sure.
  15. Jul 20, 2022 at 5:28 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Did those ball joints 43330-09510 end up fitting the OEM LCAs?
  16. Jul 20, 2022 at 6:12 AM
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    Did you check Parts.Toyota.Com? Check out Sunshine Toyota in Michigan as the source, enter FreeShip at checkout. $265 for that LCA with free shipping. Can't beat it.
  17. Jul 20, 2022 at 9:59 AM
    Nomad26
    Nomad26 Well-Known Member
    Escondido, CA
    '16 MGM OR Access Cab, ‘16 MGM RAV4 Hybrid
    Replaced mine with Moog and they have been solid so far. Plus they are greaseable. I was able to change them out using the free rental ball joint kits from Oreillys. It wasn’t easy but my boyfriend and I got it done in an evening.
    The only tip I have if you do the install is that you make sure it’s oriented correctly per the instructions otherwise the zerk fitting won’t be in the right position to grease it later. Trust me on that one, ha!
    Edit to add that the Moog PN is K80827
