Lower ball joints brand?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Holy schmidt, Aug 24, 2014.
  1. Aug 24, 2014 at 6:48 PM
    Holy schmidt
    Holy schmidt [OP] Well-Known Member
    Wyatt
    Nebraska
    So Ive had a popping/bang whenever I back out of my driveway and my front tires go down the curb. Anyways I looked under the truck and my lower ball joints are seeping grease but I cant find a tear although its dry rotted some. Would the bang im hearing be the lowerball joints or something else and what would be the best ball joints to get? Ive heard OEM and also moog and some say nappa so im unsure of what to get.
  2. Aug 24, 2014 at 7:43 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I just ordered all 4 Moog ball joints from Rock Auto. I was told this was a highly recommended brand.
  3. Aug 24, 2014 at 7:52 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    If you can afford OEM go with that, I've seen worse things happen with moog replacements rather than OEM
    BlackSportD likes this.
  4. Aug 24, 2014 at 8:08 PM
    Holy schmidt
    Wyatt
    Nebraska
    Where is a good place to get OEM I havent seen a price on them?
  5. Aug 24, 2014 at 8:09 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I think rock auto does not sure 100% I'm sure somebody knows on here
  6. Aug 24, 2014 at 8:16 PM
    Holy schmidt
    Wyatt
    Nebraska
    I just checked camelback toyota parts and its $188 for both lowers and then ~$100ish for the alignment (I need one with that right?) Im about to check rock auto
  7. Aug 24, 2014 at 8:21 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Yea I'm pretty sure you do
  8. Aug 24, 2014 at 8:27 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    I would go OEM only!!!
  9. Aug 24, 2014 at 8:35 PM
    Holy schmidt
    Wyatt
    Nebraska
    Changing it looked fairly simple just disconnect the tie rod, the 4 bolts holding on the spindle and the castle nut. Is there anything else I need to watch for when changing them?
  10. Aug 24, 2014 at 9:12 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Check low range off-road, they have a video on how to do it. Might as well do the tie-rods while your in there. Those you could get away with moog
  11. Aug 24, 2014 at 11:00 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Only oem for lower ball joints. Camelback toyota is good. I get mine from toyotapartsbarn
  12. Aug 24, 2014 at 11:03 PM
    skynet
    skynet Well-Known Member
    San Diego
    13 TRD Sport
    Scattered 12g shotgun shells in the bed to deter tweekers from stealing my stereo
    Never heard so many negative moog comments... Interesting.
  13. Aug 25, 2014 at 4:01 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Don't need an alignment with ball joints.
    btu44 likes this.
  14. Aug 25, 2014 at 4:03 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I have been using moog parts for 35 years without a complaint...and in my opinion, they are the NAME brand to use. Most of the US automakers used them for decades as their OEM chassis parts.
    Howard
  15. Aug 25, 2014 at 5:51 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    x2 - Having just performed this Preventative Maintenance (PM).
    No alignment is necessary.
    OEM - read more threads on this component and you will want to spend the few extra $$ for the OEM pieces.
  16. Aug 25, 2014 at 7:09 AM
    hetkind
    Howard
    Johnson City
    Are the MOOG balljoints greaseable? We just changed out $300 of drag links and tie rods on the Jeep JK and replaced them with greaseable MOOG components.
    Howard
  17. Aug 25, 2014 at 7:13 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    You will need a 2 jaw puller and be sure and use Loctite on the bolts when you reinstall.
  18. Aug 25, 2014 at 8:07 AM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    They sure are
  19. Aug 25, 2014 at 8:22 AM
    Holy schmidt
    Wyatt
    Nebraska
    This is for the tie rods I assume? If so I have one that fits them
  20. Aug 25, 2014 at 8:28 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Yes, for the ends. I used this:
