Lower ball joints brand?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Holy schmidt, Aug 24, 2014.
  1. Aug 30, 2014 at 6:08 AM
    #41
    JAGER91374
    JAGER91374 Well-Known Member
    Des Plaines
    3 TRD O/R
    OME 883's and Dakars, OME Shocks, Gray Wire, Deck Plate, Blacked Out Chrome, RAT Skids, BAMF BPV Bracket, Toytec Diff Drop, Braided Extended Brake Lines Front and Rear, In-Dash Nav.
    On a part as critical as the ball joint I wouldn't consider anything but the OEM pieces.
    After pricing out a compete front end rebuild (uppers, lowers BJ's, inner and outter TR's, boots and bushings) and on my truck I ended up going all OEM with the exception of the bushings. Buying parts off Rock Auto and other suppliers would have only saved me about $100. For the extra $100 I have piece of mind that I'm using the same quality parts that got the truck to 180K miles and I got everything from one place.
  2. Feb 26, 2020 at 10:30 PM
    #42
    DimeGirlTX
    DimeGirlTX Member
    Marie
    Spring Tx 77373
    1997 Toyota Tacoma Extended cab 2.4, RWD
    Trying to keep it in shape and running nicely.
    What do you think of Proforged lower ball-joints if dealership is not in the budget?
  3. Feb 26, 2020 at 10:34 PM
    #43
    Kwikvette
    Fresno County
    4 run, 2 don't
    If you can't get OEM, at the very least go with 555 (found at Low Range Off Road)
    Wow thread from 2014 lol
    SnowroxKT likes this.
  4. Feb 26, 2020 at 10:53 PM
    #44
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I agree with @Kwikvette .. 555 would definately be my choice over Proforged.
    Low Range Offroad... and also the Moogs at Summit Racing are stamped 555 as well.
    jbrandt likes this.
  5. Feb 26, 2020 at 11:01 PM
    #45
    Wulf
    Wulf no brain just damage
    rock raisin
    I don't know if Low Range carries the ones for a 5 lug...
  6. Feb 26, 2020 at 11:06 PM
    #46
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oof didn't realize the "2.4"
    Aren't the bracket or some other part the weak point on those rather than the ball joint itself?
    @Das it mang
    @Sperrunner
    Das it mang likes this.
  7. Feb 26, 2020 at 11:08 PM
    #47
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    lol... good call... I rarely even think about 5 lugs. Seems we are always talking 6 lug here.
    DimeGirlTX and Kwikvette like this.
  8. Feb 27, 2020 at 12:52 AM
    #48
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Ive gotten oem off camel back and the high end mevotech from rock auto
  9. Feb 27, 2020 at 12:55 AM
    #49
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You also have to separate the tie rods from the lbj when you change them. So it doesn’t hurt to change at the same time if you feel up to the task
    DimeGirlTX likes this.
  10. Feb 27, 2020 at 1:55 AM
    #50
    DimeGirlTX
    DimeGirlTX Member
    Marie
    Spring Tx 77373
    Thank you for the response. I recently learned about the 555 stamped parts. I also liked the ball joint video that was posted on this topic it helps tremendously. I have had my truck for many years and never thought twice about what ball joints I had installed until it happened to me... I was driving and I skidded safely into a parking lot. This has happened to others driving since it use to be a work truck. I know a long time ago they even had a recall on the ball joints so I am glad I have some solid options. I noticed after I got my truck back from installing Bilstein German shocks that 1 ball joint now has a cut in the sealed ball joint boot. I am going to change out my Proforged because of this but i have had no problems to date with this brand. I would like to know if others have had any problems. I will not use MOOG or Mevotech i have used them in the past and they broke before there warranty was up. I have been through 7 balljoints.:rofl:
    cruiserguy likes this.
  11. Feb 27, 2020 at 5:22 AM
    #51
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Thank you for chiming in.... This is exactly what happens when you run cheap Chinese crap ball joints like mevotech and proforged.
    Is there a reason you haven't gone with OEM in the last 6 ball joints??? Ohhhhh I see, they were that lifetime crap warranty, where we guarantee your part will be crap for life. :rofl:
    Yes, go with OEM. No more mistakes. You know first hand yourself.
  12. Feb 27, 2020 at 6:26 AM
    #52
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    I'm late af but moog ball joints have had good results for 5 luggers on here so need to stress oem like a 6 lug. The OEM LBJ's are not as pertinent of an issue bc we differ from 6 lugs in our suspension
  13. Feb 27, 2020 at 6:27 AM
    #53
    Das it mang
    Az
    1996 T100 SR5 MT
    just an fyi if you would rather not spend double the money. Right and left moog lbj's on Amazon are 36 bucks each lol.
    And the lower ball joint bracket is only a concern if u go above a 31 inch tire and u launch the truck like it has long travel :homer::homer:
  14. Feb 27, 2020 at 6:29 AM
    #54
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Kwikvette and Wulf like this.
  15. Feb 27, 2020 at 6:45 AM
    #55
    cruiserguy
    Elijah
    SEKS
    Did you read her post? She broke 7 of those aftermarket ball joints.... She doesn't want to replace anymore with the free warranty
  16. Feb 27, 2020 at 6:48 AM
    #56
    Das it mang
    Az
    1996 T100 SR5 MT
    @cruiserguy no I just jumped in the convo dry on coffee my b. This is the first ive heard from a 5 lugger about moog's being dooky. how may miles have u put on or what do u even do to the truck to go through 7 fkn balljoints??? crazy to me,wow
  17. Feb 27, 2020 at 6:52 AM
    #57
    cruiserguy
    Elijah
    SEKS
    Yeah I figured you just didn't see her post above mine, I answered her directly. And normally I'd think she could get away with your suggestion. In her case, she's tired of the free warranty crap and just wants the part that will have the best chance at lasting longest. And that part would be the OEM ball joint. Can't say I blame her.
    Das it mang[QUOTED] likes this.
  18. Feb 27, 2020 at 7:22 AM
    #58
    Das it mang
    Az
    1996 T100 SR5 MT
    yup, true true.
    I'll be going with moog when that time comes, so guess I can add to the "experience list" of 5 luggers.
    Just still blown away with 7 balljoints unless we're talking jumping the truck every weekend or 5-6 hundred thousand miles on the truck
    El Taco Diablo and Wulf like this.
  19. Feb 27, 2020 at 8:21 PM
    #59
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Been through 7 ball joints?
    Ya, there's another issue causing that... and it has absolutely nothing to do with what brand ball joints they are.
  20. Feb 27, 2020 at 9:27 PM
    #60
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
