Lower control arm bushing replacement needed? cracking, popping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Byb127, Oct 18, 2017.
  1. Oct 18, 2017 at 1:24 PM
    Byb127
    Byb127 [OP] LIFTED..leveling and chopping...
    Brandon
    San diego
    2014 Tacoma long bed 4x4
    King 2.5 w/ Resi F/B Icon UCA's Stealth custom series Ray10 wheels Apex/Caliraised light bar stealth mount
    2nd Gen LCA's, not sure about fitment for other years.
    After some searching through all the different methods I found the full set for a decent price.
    Seems like a lot of people have gad trouble getting their bushings out or having mixed results as far as noise goes shortly after install.
    This set right now is about $178
    most bushing sets are around $100
    Is $78 worth not having to replace bushings? you decide.
    Also comes with a 10 year warranty.
    https://www.ebay.com/itm/131802962366
  2. Oct 18, 2017 at 1:30 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 70 17 cooper at3 Demello front bumper Brute force rear bumper
    10 year warranty!!! I’ll take a set. I have order from them before and their customer service is very good. Got a replacement window regulator with no hassle from them.
  3. Oct 18, 2017 at 1:53 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    tighten bushings on level ground with truck off the jack
    $120 more and get the uppers too from same ebay seller
    Autotruckin likes this.
  4. Aug 9, 2018 at 2:19 PM
    RyaanJaansen
    RyaanJaansen Member
    RJ
    07 4x4
    Did you end up grabbing these LCAs?
  5. Aug 9, 2018 at 2:26 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Might want to look into cam tab and bolts pricing. You may or may not be able to salvage them and they are not cheap.
    I cut two of mine out :sawzall:other two came out with an air chisel.
    Hartford likes this.
  6. Aug 9, 2018 at 8:08 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Almost the same story here. Cut all four of mine. Definitely look into new cam bolts.
    Also I don't believe any bushing styled after the OEM's are going to last ten years, unless you never leave the pavement and you drive less than 10k a year.
