Lower Control Arm Bushing Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by newoldstaco, Aug 8, 2025.
  1. Aug 10, 2025 at 8:41 AM
    Red_03Taco
    Red_03Taco @ the Taco Shop
    Jerad
    Yavapai County, AZ
    2003 Tacoma Xtra Cab 4WD
    Eaton E-locker (rear), Alcan Leafs, Toytec 2.0s (rear), Icon 2.5s (front)
    Should be fine then. Probably worth saturating them with some PB Blaster or other penetrant a couple of times in the week or so prior to trying to remove them.
  2. Aug 10, 2025 at 8:42 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    OEM complete arms is 100% the way to go! Pressing bushings can be a real PIA. Sometimes it goes smoothly. Sometimes it doesn't. Labor cost/install time is less by replacing the whole arm, so factor that into the cost of the part.
  3. Aug 16, 2025 at 9:28 AM
    newoldstaco
    newoldstaco [OP] Well-Known Member
    I tore into it with a more experience friend than who pointed it out… he was like there is absolutely NOTHING wrong with you control arm or bushing. lol. Turns out the knocking was my drive shaft center mount being warn out giving it a little play. Swapped out the tie rod ends and the mount, changed my oil and filter. Knocking appears to be gone. Getting new tires and an alignment. Headed to VT for a road trip!
    SpencerTacoSC and shankyjones like this.
