Lower Control Arm, More Caster
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dirty Pool, Jan 12, 2020.
  1. Aug 8, 2020 at 10:28 AM
    Dirty Pool
    Dirty Pool [OP] FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    So continuing with the blistering pace of this project...
    Skimmed some funds from the "trail fuel" account and made a risky capital expenditure.
    Three "heavy pattern" washers to look at, day dream about and play with. They are 3/16" thick.
    Compared to regular washers.
    After that feat I had another thought. I'll let it out before it dies of solitary confinement.
    I figured I should be ready for a test fit next time the front end was apart. Problem, I needed bushings and could not justify raiding "trail fuel" again.
    A few minutes on the wood lathe yielded some mock up bushings from stock on hand. And not just any stock, it's Ancient Kauri. The stuff is 40-50 thousand years old (not petrified). Dredged up from New Zealand peat bogs. https://en.wikipedia.org/wiki/Swamp_kauri
    Exhausted
    970btu, jubei, turbodb and 1 other person like this.
  2. Aug 8, 2020 at 10:49 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Hahahah:rofl:
    You describing the wood test/trial pieces totally reminded me of one off the funniest flicks ever made: Meet the Parents.
    So many funny clips in that but this part where he chose a Bolivian wormwood:rofl::
    https://youtu.be/ETC82KEplac
    And this part where he salvaged the wood from an old seamen's chapel off the coast of Nantucket: :rofl::rofl:
    https://getyarn.io/yarn-clip/cb12e574-6154-4eb7-8768-fdbe8805a8e4#kEwaauP8JP.copy
  3. Jan 27, 2022 at 11:12 AM
    970btu
    970btu Well-Known Member
    Ty
    Las Vegas
    99 Tacoma 3.4 5spd ext limited TRD 55K and counting
    OME, SPC UCA, ARB w/warn 10K winch, TG Rock Defense Rear, Marlin Clutch, Custom hi clearance under bed spare mount. 285/75/16. A ton of repairs done and a list up to come modifications.
    Instead of the bolts, how about hot riveting?
    Could you heat a rivet enough with a rosebud, and use some adapters on a shop press to put rivits back in place?
    The should be stronger than bolts with more clearance on both sides. If there was to be contact top or bottom a smooth surface would be better than the bolt surface.
    https://youtu.be/5aTL0Jvrf4I
    On another note..
    Do you have any ideas about installing the rear LCA bolt the other way so next time the rack doesn't have to be pulled to do the bushings?
  4. Jan 27, 2022 at 11:19 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I don't believe that works as the side with the nut is longer and thus hits the steering rack if installed backwards.
  5. Mar 21, 2024 at 10:56 AM
    Cattywampus
    Cattywampus Splitter of CV Boots
    Mark
    Colorado
    '03 Tacoma DC TRD OR
    @Dirty Pool , Any progress or updates on this? I love this idea for gaining firewall clearance. Do you have any pics of it installed on the truck?
    Going back to your hardware stack up, how did it hold up? It was suggested that you could weld this. Any adverse effects from welding on a forged part?
    TuRDLYFE likes this.
