Lower control arm parts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bryce Dahlstrom, Mar 7, 2024.
  1. Mar 7, 2024 at 4:08 PM
    Bryce Dahlstrom
    Bryce Dahlstrom [OP] Well-Known Member
    Bryce
    2003 Toyota Tacoma
    Just 1.25 inch spacers so far
    Just a quick questions. Where’s the cheapest reliable place to get OEM lower control arm bushings and ball joints?
  2. Mar 7, 2024 at 4:23 PM
    hucklebarry
    hucklebarry Well-Known Member
    casey
    02 tacoma
    arb bumper, warn 8000 winch, arb air pump, arb front locker, and old man emu lift
    I like yotaparts.com. You should order the alignment cam bolts also. Most likely they’re frozen in place and will need cut out.
  3. Mar 7, 2024 at 4:41 PM
    Lugnutz
    Lugnutz Member
    03 Tacoma 3.4 4x4 DC
    Jumping in, I'm going to do the exact same project soon. On a truck with minimal rust, it's reasonable to replace just the bushings and not the entire control arm assembly, right? I went to a machine shop today to verify that he'll be able to press out/in the new bushings for me, and even he suggested that I do the whole assembly. Which I don't feel is necessary.
  4. Mar 7, 2024 at 4:50 PM
    hucklebarry
    casey
    02 tacoma
    I just got done doing just the bushings and alignment bolts. Had a hard time cutting the old cam bolts. I recommend buying good sawzall blades with a high tooth count and lots of lube. When the blade got dull I cut it off with a grinder. It took 3 Milwaukee torch blades…
    Superdave1.0 and Lugnutz like this.
  5. Mar 7, 2024 at 6:45 PM
    Lugnutz
    Lugnutz Member
    Thanks for the tip on having planty of sawzall blades. How did you press the old bushings out?
  6. Mar 7, 2024 at 6:54 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    As of last year my price comparison. Welcome to TW.
  7. Mar 7, 2024 at 6:54 PM
    Clearwater Bill
    Billy
    Largo Florida
    Old out can be cut or even burnt. Getting new in is more challenging
    Lugnutz[QUOTED] likes this.
  8. Mar 7, 2024 at 7:04 PM
    hucklebarry
    casey
    02 tacoma
    I fought the first one trying to take the hole thing out at once with a press. Then decided to use a small bottle jack to press the rubbers out. After that I took a sawzall and vary carefully cut two cuts per sleeve 99.99% through. Took a pinch and drove them out. Take your time it wasn’t that bad.
    Do not cut to far!!!
    Lugnutz likes this.
  9. Mar 7, 2024 at 7:12 PM
    hucklebarry
    casey
    02 tacoma
    I also cut through the bushing not in between the bushing and the frame to get the cam bolts out. I didn’t want to knick the frame.
    Lugnutz likes this.
  10. Mar 8, 2024 at 9:41 AM
    MT-98
    MT-98 Well-Known Member
    Montana
    98 Tacoma
    Sorta Stock
    I used a sawzall, too. After trying to press and burn them out. The vise/bottle jack/torch method didn't work for me, though I tried. What it did do was actually spread the control arms apart a little and I had a hard time getting them back in the truck, because they were stretched out just a tiny bit.
    It's not a terrible job, especially if you've done balljoints before. Like a lot of this stuff, the first side took me hours. The second side went fast. I also live in a pretty rust-free area so I didn't have to deal with much corrosion.
    hucklebarry and Lugnutz like this.
  11. Mar 8, 2024 at 11:15 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    If you want your lower control arms to last another 20 years, I'd suggest buying the complete Toyota LCAs and swapping them. As someone who replaced just the bushings, and had no need to cut anything to remove the LCAs or the old bushings, I'd still recommend replacing them with oem lower control arms with the bushings already installed (which I did later anyway). A bit more money, but way less work, and will be like it was new.
    Many will disagree with me, I'm sure.
    rocknbil likes this.
  12. Mar 8, 2024 at 11:17 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Remove LCA's
    Push out bushings with bottle jack; some people burn them out
    Replace with Whitelines
    Reinstall
    Was super simple, don't see why anyone would buy new arms
    As for balljoints, buy them online from Toyota
    Lugnutz and Andy01DblCabTacoma like this.
  13. Mar 8, 2024 at 11:17 AM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Depends on where your truck has been over the last 20+ years. Mine came out without any issue.
    Lugnutz likes this.
  14. Mar 8, 2024 at 7:26 PM
    hucklebarry
    casey
    02 tacoma
    You got lucky . Most cases it’s a slice and dice.
  15. Mar 8, 2024 at 7:34 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Save yourself a lot of headaches and time and just get new control arms.
  16. Mar 8, 2024 at 7:36 PM
    hucklebarry
    casey
    02 tacoma
    And just throw good parts in the garbage It’s not that bad.
  17. Mar 8, 2024 at 7:48 PM
    Lugnutz
    Lugnutz Member
    Even with the use of a press?
  18. Mar 8, 2024 at 8:11 PM
    hucklebarry
    casey
    02 tacoma
    At just under 250 per side for oem control arms, or 120 for both sides for oem bushings. There’s no way. It took an hr to change them out. Took about two hrs to cut the cam bolts. Which may have to be done ether way. Sounds better than sitting on the couch.
  19. Mar 8, 2024 at 8:20 PM
    hucklebarry
    casey
    02 tacoma
    That’s what I tried first. The spread of the two bushing cups was just too small for my press. Didn’t want to put that much pressure on them.
  20. Mar 8, 2024 at 9:34 PM
    Lugnutz
    Lugnutz Member
    Thanks for the input, I appreciate it!
    hucklebarry[QUOTED] likes this.
