Lower control arm parts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bryce Dahlstrom, Mar 7, 2024.
  1. Mar 9, 2024 at 6:09 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I didn’t need a press to get the old bushings out, just a bottle jack, popped right out. Sonoran Steel bushings went in,
    Easy Peasy
    Lugnutz[QUOTED] likes this.
  2. Mar 9, 2024 at 9:19 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    I have had situations where a 20 ton press would not move the bushings. Had to use an air chisel to get them out. Time wise, I have found it is just easier to replace the whole unit. That's my experience - YMMV, but for the money, and the time, it's just a better proposition.
    Superdave1.0 and glwood6 like this.
  3. Mar 10, 2024 at 8:44 PM
    CA-Taco
    CA-Taco Well-Known Member
    Santa Cruz Mountainss
    1999 PreRunner TRD
    1999 PreRunner TRD 5VZ 3.4 V6 AutoTrans 4x4 Swap ADS Coilovers w/adjusters New OEM Bushing UCA and LCA @210k Mi Stock LCA, SPC UCA REH5108 Coilbucket Gussets Total Chaos Spindle Gusset DuroBump Front Bump Stop Alcan Springs +800 lbs +2" ADS w/adjusters Rear Shocks U-Bolt Flip-Durobump DuroBump 4.25” Bump Stops Custom Shock Relocation 4.88 Yukon Gears Eaton Front Locker SCS Ray10 16x8 Bronze 255/85R16 Cooper Discoverer S/T Maxx Dakota Digital SGI-100BT Speedometer Interface Stock Front Bumper with Custom Hidden Winch Warn M8 w/Synthetic Rope w/Factor55 Flatlink E Nguyen Works Bumper w/Dual Swing Outs (Greasable KP Off-road LCA Bolts for Swing Out Bearings) BAMF Sliders 4x Innovations Front and Transmission Skid Plates Dometic CFX 55im Fridge/Freezer Big 4 wiring Mod Singer 128.5MM Denso hairpin style (6 phase) 180 A (200 A Max, 150 A Idle) X2Power AGM Group 35 Battery Renogy Deep Cycle AGM 12 Volt 100Ah Battery Renogy 20A DC to DC Battery Charger Victron Energy SmartShunt 500 amp Battery Monitor BlueSea Bus Bar on Custom Engine Bay Mount Victron Energy SmartSolar MPPT 20 amp Solar Charge Controller Renogy 100 Watt Eclipse Foldable Solar Panel Osram Super Bright 100/90w 2900 lumen H4s Headlight Services Harness 13WL Brake Calipers Braided Steel Brake Lines OBDLink MX+ OBD2 Bluetooth Scanner & OBD Fusion App Kenwood DMX958XR Soundproofed Cab - Dynamat and Second Skin Wet Okole Seat Covers Rebuilt Engine when Head Gasket Failed (215k Mi) Hayden 699 Transmission Cooler (Replaced B&M 70264 Cooler) Magnetic Inline Transmission/Power Steering Filter 4 x 4 Conversion w/Yota1 Rebuilt AT, ECGS Rebuilt Front Diff, '99 Taco TC, Manual Hubs GFC Camper V2 LSPV Delete Funky Home Made Mud Flaps and Hangars (1/4” Conveyor Belt Material; 12” x 18”)
    Lugnutz likes this.
  4. Mar 10, 2024 at 8:53 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I still recommend new complete arms. Some have had bushings that were hard to get in/out. Do you want to save time and effort, Or money?
    Also are your old arms in good condition? possibly bent? Rusty?
  5. Mar 11, 2024 at 5:06 PM
    Bryce Dahlstrom
    Bryce Dahlstrom [OP] Well-Known Member
    Bryce
    2003 Toyota Tacoma
    Just 1.25 inch spacers so far
    Would u recommend buying the complete LCA’s from Toyota or another company?
  6. Mar 11, 2024 at 6:02 PM
    Lugnutz
    Lugnutz Member
    03 Tacoma 3.4 4x4 DC
    consensus is to buy OEM LCA's.
    glwood6 and Superdave1.0 like this.
  7. Mar 11, 2024 at 9:26 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    I got oem LCAs from an online Toyota dealer who had the best price and free shipping. I can go back and see where if you'd like.
    Edit: https://autoparts.rosevilletoyota.com/ - best price I found at the time with free shipping. Last April. YMMV
  8. Mar 12, 2024 at 5:39 AM
    hucklebarry
    hucklebarry Well-Known Member
    casey
    02 tacoma
    arb bumper, warn 8000 winch, arb air pump, arb front locker, and old man emu lift
    That’s a grate deal.
