Lower Control Arm Replacement Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 508Tacoma, Oct 8, 2021.
  1. Oct 8, 2021 at 10:58 AM
    508Tacoma
    508Tacoma [OP] Well-Known Member
    MA
    2017 TRD OR 4x4 DCSB
    Just recently had my 2017 TRD OR in for some routine maintenance and to correct some alignment issues at a local Toyota dealer. After the alignment the tech noted that the lower control arms had seized and need to be replaced. I was quoted $2K for parts, labor and a new alignment. My first thoughts were, cant I just have the cam bolts replaced (sawed or drilled off) without replacing the entire LCA. Anyone have any suggestions on how to proceed? This just seems a bit steep. Thanks
