Lower Control Arm Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by imjustabill1970, Dec 20, 2019.
  1. Dec 20, 2019 at 6:57 PM
    imjustabill1970
    imjustabill1970 [OP] Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    Okay...so I just had my Icon Stage 4 installed. The shop that did the install said that my bushings were bad and that I should replace the lower control arms because the bushings in them can't be replaced as a stand alone item. True?
    Recommended Total Chaos Lower Control Arms but those suckers are pretty pricey!
    Thanks,
  2. Dec 20, 2019 at 6:59 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yep.
    imjustabill1970[OP] likes this.
  3. Dec 20, 2019 at 7:00 PM
    Bishop84
    Bishop84 Well-Known Member
    Why are they bad? Seized? I havent seen any 3rd gens that need lower arms. Seems like a really pricey thing to buy just because a shop said to.
    I wouldn't replace them or the bushings. I usually have to change arms when the truck is 10 years old and I cant move the eccentrics.
  4. Dec 20, 2019 at 7:07 PM
    imjustabill1970
    bill
    clarksville, tn
    Didn't exactly say. They said that when they test drove it, they noticed a knocking sound when the brakes were applied and the vehicle was turning. Then they said they checked it to confirm.
    With that said, I did NOT hear it on the way home. But, I have (on a few occasions) heard a one-time knock when I back up with the wheel turned (even before the install). It does not happen often, just every once in a while and I have not noticed any drop in performance.
  5. Dec 20, 2019 at 7:19 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    If you have to fix the stock bushings just buy new stock Lowers. Less work to replace.
    if you are cool you will ask a fabricator to build new lower control arms out of 4130 steel , uniball replacement for the ball joint ... and , and uniball replacements for the bushings pivots (the total chaos Lowers have lame bushings). Don’t believe any propaganda about longevity of a bushing vs a uniball pivot, always go uniball or heim joint
    Nm camburg makes them :
    http://camburg.com/shop/suspension/camburg-toyota-tacoma-pre4wd-05-15-performance-lower-arm-kit/
    hiPSI and imjustabill1970[OP] like this.
