lower control arm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by willard417, Mar 19, 2010.
  1. Mar 19, 2010 at 8:48 PM
    willard417
    willard417 [OP] Yeah
    Luke
    beaver county, PA
    06' access cab. 2.7L
    alpine head unit, removed secondary air filter, 18" XD Rockstars. 285/60/R18, 3" OME 884/AAL OME shocks all around.
    so it turns out that the alignment shop can't get the adjustment screw to move on my lower control arms. anyone else have this problem or know where i can get some new ones?
  2. Mar 20, 2010 at 8:14 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    If you are talking about the alignment cams, they are replaceable without the control arm assembly and can be purchased at the dealer. It is very common for them to seize. If you also need new control arms, they can also be purchased at the dealer but are very $$$ as they include the ball joint.
    No aftermarket alternatives at this point in time - dealer only. If you aren't in a rush, try one of the site vendors as you'll save a few bucks.
