Lower Control arms and why I went with OEM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by knottyrope, May 12, 2020.
  1. May 28, 2020 at 2:10 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Pay shipping and you can have mine. 49,133 miles, one bad ball joint
    Island Cruiser likes this.
  2. Jan 6, 2021 at 2:31 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    I know this is old but I Just thought I’d add to the thread:
    I replaced my driver side LCA this last weekend (leaking ball joint). I had read the horror stories about seized bushings etc. and I was prepped with new oem hardware and a new oem LCA from McGeorge Toyota (best prices I could find ~$340 all in, my dealer wanted $625 to change it out). It took about 1.5 hours total (working slow and hanging out with my dad). Super easy.
    I was ready to go with carbide tipped sawzall blades and everything - only to have the sleeve and bolts come out with a light tap of my dead blow. Like literally a test tap. I am keeping the old hardware (looks brand new) in case I need to do it again but I won’t buy new stuff the next time.
    on the flip side - it took my big sledge to knock the ball joint loose from the knuckle connector piece. Go figure.
    I put a medium coat of marine grease on the inside of the bushings and the cam sleeve and bolts. Adjusters were left dry of course.
    On a side note- the aftermarket hardware that I have seen DOES NOT compare to the OEM Toyota cams/adjusters/bolts. I highly recommend spending the 60 bucks on OEM stuff.
  3. Jul 18, 2021 at 8:33 PM
    chrisduncansb
    chrisduncansb Member
    Portland, OR
    2013 Tacoma TRD Sport DCLB
    6" lift with 35x12.5 M/Ts. Lift is coming off soon though.
    Still got them? I'll take you up on that! I just bought a 2013 with a 6" rough country lift that I'm taking off.
  4. Jul 18, 2021 at 9:14 PM
    TacoTuesday1
    SD CA
    currently running $30/ea aftermarket LCA's
    Zero Issues
    Jumexmessiah likes this.
  5. Jul 19, 2021 at 4:21 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Zero issues for how many miles? Report back to us if they last anywhere near as long as your OEM originals. That's the real test.
  6. Feb 10, 2022 at 3:17 PM
    PhxRising85
    PhxRising85 AMSOIL Dealer
    Logan
    Surprise, AZ
    2008 SR5 2WD LB Tacoma
    Fox 2.0 Suspension, Diode Dynamics Driving Lights, AMSOIL
  7. Nov 21, 2023 at 1:03 PM
    milesvanren
    milesvanren Well-Known Member
    miles
    Lopatcong, NJ
    05 tacoma trd 4wd v6
    Step bars, custom bumper, winch
  8. Nov 21, 2023 at 1:04 PM
    milesvanren
    miles
    Lopatcong, NJ
    Still have pair of OEM LCAs?
  9. Nov 21, 2023 at 1:26 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Lol no. The post was 3 years ago
    Island Cruiser and Micbt25 like this.
  10. Feb 16, 2024 at 8:59 AM
    ghardy
    ghardy Well-Known Member
    Montana
    2013 Tacoma TRD Off-Road
    TRD Badged 5100 3rd Gen 2" Lift with ICON RTX Rear Leafs
    Hey! How'd the $30 ones go for you?
    Thinking of foing some MEVOTECHs as I've had fantastic experiences with them on other vehicles buuuut the cheapies are always tempting.. looking at TRQ LCAs too
  11. Feb 16, 2024 at 9:33 AM
    Muttley
    Muttley Member
    Paul
    Pasadena, CA.
    TRD Off Road
    I'm using Mevotech Supreme Lower Control Arms (left & right side). I only have 20k miles over 2.5years, and so far they're holding up fine. "Limited lifetime warranty" on these, but take that with a grain of salt.
    Maybe useless info, but my truck has a Eibach Pro Lift stage 1 kit, and 18x9" 0 offset wheels. The offset on the wheels really does put more stress on arms and joints and steering. So I always check the bushings and do a ball joint shake test at every oil change since I'm just as concerned as everyone else with the quality of aftermarket parts.
  12. Feb 16, 2024 at 9:33 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    At 70k miles in 2017, I changed the suspension on my truck. Cam bolts were seized. Took it to my mechanic, big and costly mistake.
    Now, with 131k miles, I was charging the suspension again. Noticed my ball joints were getting bad. I found new(300 mile) lca's for $250.00. I figured, why not, new ball joints and new bushings.
    Cam bolts came out easy, because last time I told the mechanic to cover them with anti seize.
    Before you start mark your cams and take pictures, so you get the alignment real close.
    In case your wondering, in 2017 I replaced the stock suspension on my 2013 with the TRD Pro suspension when discontinued the Bilstein kits that they used in 2015. I went to Dobinsons system.
    The Wisconsin TW crew encourages spending money on our truck.
    After adding more weight I needed the heavier coil spring. That's when I noticed my ball joints.
    astonb86, wi_taco and ghardy like this.
  13. Feb 16, 2024 at 12:21 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I have the standard MevoTech's on mine after my OEM LBJs failed. I've had them on for maybe 25-30k miles with some pretty aggressive wheeling here and there. No problems so far, but we'll see.
  14. Feb 16, 2024 at 3:18 PM
    TacoTuesday1
    SD CA
    Not good. Some of the dimensions seemed wonky like bushing diameters and supposedly one was too short, messing up alignment. Ball joint and bushings might not have been good quality but didn’t run them long enough to find out.
    I had too much positive camber on one side with the adjusters maxed out. At first thought it was from lift height but it was not max height. Was probably caused by that LCA.
    ended up finding a used worn out OEM takeoff set and replaced it with new bushings and LBJ’s from RockAuto and repainted them.
    learned the hard way at least once why folks recommend OEM brand new. Also heard some people reinforce OEM with welding.
    I really don’t know how the Moog or Mevotech bushings and LBJ I have installed in my LCA compares quality wise to a whole new arm from the dealer.
    They are greasable (LBJ zerk). Eventually one started squeaking. When I greased it the squeak stopped.
    not sure how poly bushings compare either.
    a few companies do have welded steel LCA’s in stock width for non long travel, or one company’s that shifts wheel position forward 0.75” to clear bigger tires - they’re just expensive. I forget which is which but I think Solo Motorsports, Dirt King, BTF Fabrication, maybe more.
    ghardy[QUOTED] likes this.
  15. Apr 19, 2024 at 1:04 PM
    #35
    astonb86
    astonb86 Well-Known Member
    Aston
    2011 Tacoma TRD Off-Road
    I also swapped to a Dobinson rear suspension and after a bit noticed my LBJs seeping grease. Might be a thing, maybe additional pressure on the front end with such heavy springs. :confused:.
    Taco-Grinder[QUOTED] likes this.
