Lower Control arms - replace bushing or whole arm?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sack17, Apr 14, 2016.
  1. Apr 14, 2016 at 6:13 AM
    Sack17
    Sack17 [OP] Well-Known Member
    Andrew
    Sanibel, FL
    05 Tacoma DBL Cab TRD Sport 4x4
    Bed lights Blacked out sport wheels blacked out emblems BHLM Spidertraxx 1.5" wheel spacers factory roof rack custom yakima wind fairing w/ PIAA off road lights up top snowboard/ski rack surf board pads fog light mod custom interior cup holder l.e.d. lights Bestop topper custom L.E.D. rear facing lights Maglite mod (2 front seats) 3.25" in the front 2.5" in the rear 6 Hella 500ff's (w/ Silverstar's) Silverstar Ultra's in headlights Silverstar Ultra in fogs (retro-fitted 65w 9005's) Hi-Lift (mounted on side of bestop) Shovel (mounted on side of bestop) custom 1.5" body lift
    So like a handful of you all it sounds like my passenger side cam bolt sleeve is seized inside of the bushing (passenger front closest to the front bumper).
    Question 1) Can the stock arm bushings be replaced fairly easily once the arm is removed?
    Question 2) Can I replace the stock bushings with poly's in the stock arms?
    Question 3) Would it be way easier to just replace the arm completely so it comes with all new bushings and lower ball joint?
