Lower Control Arms - Skid Plates
Discussion in 'Suspension' started by imjustabill1970, Dec 14, 2021.
  1. Dec 14, 2021 at 12:33 PM
    imjustabill1970
    imjustabill1970 [OP] Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    How needed are these or are they just a cool thing to have?
    I understand the need for them, but I just wonder...by experience here on this board, how many people have seriously banged up their LCAs while wheeling.
    Thanks!
  2. Dec 14, 2021 at 12:48 PM
    anthemAnathema
    anthemAnathema Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    Elka 2.5 w/ DSC RCI Skids AP Expedition Leafs Leer 180
    I've been wondering the same thing. I've been wheeling for years and never damaged an LCA.
    However, I can imagine a bad hit could make the drive home pretty rough if not leave you completely stranded. I'm considering adding them... for <$200 it might be worth piece of mind.
  3. Dec 14, 2021 at 12:50 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    My personal take... not needed. Your LCA's are fairly stout and adding an aluminum plate to the bottom is just going to reduce ground clearance and cause you to get hung up on rocks. Aluminum doesn't like to slide across surfaces like steel. It gouges and snags on hard objects.
    Additionally, the LCA is right next to the tire, so it would be a weird shaped obstacle that would hit the LCA and not the tire... might just pick a better line.
    However, I'm also the person that bought Total Choas Stock Geometry Expedition LCA's, which arguably have very little benefit... but they look cool!
  4. Dec 14, 2021 at 12:57 PM
    eon_blue
    Azusa, CA
    Decreases clearance at the LCAs, more likely to hang them up on stuff.
    LCAs are beefy as is. The only part really worth protecting are the cams and some IFS skids are wide enough to do that. On 1st gens anyway.
    It's not as if the lower arms are like the oil pan, tcase or rear diff, where you're potentially Fed if you smack them.
    Bertw192 and imjustabill1970[OP] like this.
  5. Dec 14, 2021 at 1:03 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Just a sales gimmick for companys to make money, since I have never seen a "broken" lca. I have never been hung up on my non-skid lcas, ever.
  6. Dec 16, 2021 at 10:56 AM
    dirt_seeker
    dirt_seeker Well-Known Member
    Utah
    2017 TRD OR
    Agreed, not needed. I was thinking about those skids early on since they were relatively inexpensive, but honestly, the stock LCA are really strong and can take a hit no problem. I would save the dollars and weight, and just leave the skids off.
    imjustabill1970[OP] likes this.
  7. Dec 18, 2021 at 12:53 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    A LCA gusset makes some sense to me, but a LCA skid plate does not.
  8. Dec 19, 2021 at 8:36 PM
    Oldskoolte72
    Oldskoolte72 Member
    Mario
    2003 Tacoma
    I believe skid plates would be useful to lowered street trucks as well I’ve caught my sway arm brackets a few times just a thought
  9. Dec 19, 2021 at 8:49 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    The only time I've damaged an LCA it was the weld on the frame mount eye that failed and a skid wouldn't have helped.
    Bertw192 likes this.
  10. Dec 21, 2021 at 10:44 AM
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    Running the RCI aluminum a arm skids on my truck. left em raw aluminum. They look good and are added protection.
    gaterose likes this.
  11. Nov 19, 2024 at 5:59 PM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    Gonna dredge this thread back up.
    We do some winter camping that takes us down deep snow covered roads. We cut some ruts on our way in that sometimes freezes back up pretty firmly by the time we drive back out the following days. After last year I noticed one of my cv boots had failed. I have full belly skids which we were dragging the whole time as we were maxed out on clearance with my 3” lift. I’m wondering if pushing dense frozen snow with the control arms and subsequently the cv axles/boot might had led to the failure. All that being said I’m wondering if this is an application where control arm skids might actually be a worthy investment?
  12. Nov 20, 2024 at 7:24 PM
    hoarder23
    Shay
    NJ
    Scratches
    The ones I had protected the LCAs, not the CV boots, they were still exposed
  13. Nov 21, 2024 at 6:11 AM
    gudujarlson
    Minnesota
    Skid plates are not required for driving on a road.
  14. Nov 22, 2024 at 10:40 AM
    Got2ryde
    Ryder
    Maryland
    Yeah that’s most of the ones I’ve seen just cover the LCA’s. Anyone know of any that might offer mor cv boot protection?
  15. Nov 22, 2024 at 11:26 AM
    hoarder23
    Shay
    NJ
    Scratches
    If you plan to ever drive through mud or snow or brush having something that protects the underside will also trap things in and is more likely to cause damage than prevent it.
