Lower control arms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by araizu1, Dec 12, 2012.
  1. Dec 12, 2012 at 9:49 PM
    araizu1
    araizu1 [OP] Well-Known Member
    Tijuana, BC Mexico
    2016 TRD Sport DCSB
    TRD Skid Plate BFG Tires Predator Tube Steps
    So here's the deal i crash my truck :( forget about the details one of the Lower control arms gets damage i need to replace it with the dealer that will cost me 200 bucks not much seems ok the price but on the other hand I'm thinking maybe if the price is right getting some better LCA's im running on camburg UCA's so what do you guys think, should i get aftermarket or OEM LCA's? and if the answer is aftermarket what brand? how much? photos if you haved will work
  2. Dec 12, 2012 at 10:00 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    X2
  3. Dec 12, 2012 at 10:02 PM
    OZ-T
    Peter North
    British Columbia
    There is no way a dealership is replacing an OEM LCA assembly for $200
  4. Dec 12, 2012 at 10:05 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    Well it probably isn't a new toyota part or a cheap aftermarket. Just looked on rockauto.com and they cheapest lower control arm you can get is $144 for 4x4 and the brand is Mevotech.
  5. Dec 12, 2012 at 10:10 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    . <--------- is called a "period" and is used to end a sentence, like this. Just wanted to share that real quick. :)
  6. Dec 12, 2012 at 10:13 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Mevotech is made in Canada. Not sure if that's a blessing or a curse. :D
    OP is in Baja Calif? $200 may be doable with a Mevotech LCA and Mexican labor rates. :notsure: IMO the LCA is easier to replace than the UCA, without a long bolt interfering with the inner fender.
  7. Dec 14, 2012 at 1:24 PM
    araizu1
    Tijuana, BC Mexico
    2016 TRD Sport DCSB
    I have a friend who works on the dealership thats the reason about the lower cost ... people reply but none respond my question do you guys know?like?agree? any suggestions? what should i do? get the OEM part o put an aftermarket? and what aftermarket?
  8. Dec 14, 2012 at 1:28 PM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Just two many English teachers these dayz on the knet.
  9. Dec 14, 2012 at 2:44 PM
    ProForce
    Anthony
    Alaska
    I know right :screwy:
    :rolleyes:
  10. Dec 14, 2012 at 5:47 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    If you want to spend about $1600 Total Chaos has some LCA's. I think it is absolutely crazy to spend that much and not go a little more to get LT. You always buy some gussets and skids for the stock lower's and put them on yourself. If you weren't forever away I'd help ya out for something to do. Depends on how much wheeling you do. All I would do is beat my truck if I lived down by you. (Baja is what I saw)
  11. Dec 14, 2012 at 7:03 PM
    ntilehman
    Seth
    Charlotte, NC
    They would be stronger if he does some wheeling. Ability to mount a second shock.
  12. Dec 14, 2012 at 8:14 PM
    ntilehman
    Seth
    Charlotte, NC
    I totally agree I didn't recommend them at all. He asked if there were options out there. I gave him one.
  13. Dec 14, 2012 at 8:19 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Camelback Toyota sells OEM LCA's with bushings and ball joints for just over $160 so I don't understand why all you seem completely shocked that a dealership is selling one for $200... :notsure:
    As said above, unless you have a need for a secondary shock, stick with OEM lower control arms. If you do have a need for that level of performance, I believe Total Chaos and Icon are your only choices unless you go long travel.
  14. Dec 14, 2012 at 10:30 PM
    BradyT88
    BradyT88 Well-Known Member
    Because the TC LCA's are so expensive I have never confirmed this (because pretty much no one owns them...) but they are supposed to have a little more articulation than the OEM although it would be minimal. In my case, my LCA's are my limiting factor in droop. I have maxed the ball joint's articulation out... but because of the massive price difference between the TC and OEM LCA's they wouldn't be worth it, especially since Long Travel is a massive improvement in travel for not much more money.
