Lower Control Arms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coopcooper, Aug 26, 2019.
  1. Aug 26, 2019 at 2:58 PM
    coopcooper
    coopcooper [OP] certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    When looking at some lowers arms, total chaos for one, it says that oe style bushing shock eyes don't work with their shock mount.
    Do 5100s fall into that category? I don't want to drop 1000+ on Lcas to find out my shocks wont work with them.
  2. Aug 27, 2019 at 12:52 PM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    They won't work. You will need a shock or coil over with a spherical bearing bottom end
    whatstcp likes this.
  3. Aug 27, 2019 at 12:56 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Yes this
  4. Aug 27, 2019 at 1:02 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Not true anymore.....
    I just ordered a set of expo LCA’s and this is from Total Chaos themselves:
  5. Aug 27, 2019 at 1:03 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Not that it matters because I’m running shocks with a lower bearing rod end anyway but there are more options now should you want to running a bushing rod end shock.
  6. Aug 27, 2019 at 1:03 PM
    coopcooper
    alberta canada
    hmmm interesting
  7. Aug 27, 2019 at 1:04 PM
    coopcooper
    alberta canada
    yeah im getting fox coilovers in the future anyways but I just wanted to make sure I didn't screw my self buying lowers that wont work with bushing style shocks
  8. Aug 27, 2019 at 1:05 PM
    reg0928
    Ross
    Crestone, Colorado
    3"OME, 255/85R16
    Yeah I'm on Fox coil overs, but this is definitely interesting info to know
  9. Aug 27, 2019 at 1:09 PM
    maxtherat
    Inland Northwest
    True mine are race series so I wasn’t thinking about the expo. Thanks!
  10. Aug 27, 2019 at 1:09 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    I ended up just going single shock because I didn’t want to run 1.25” wheel spacers but the biggest reason I went for the expo arms was the option to fit a 3.0 shock down the road when my 2.5’s are due for a rebuild.
    reg0928[QUOTED] likes this.
