Lower Control Arms?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by APaulcolyps68, Jan 21, 2025.
  1. Jan 21, 2025 at 8:27 PM
    APaulcolyps68
    APaulcolyps68 [OP] Active Member
    Paul
    2014 Tacoma TRD Off Road 2WD
    Fox Coilovers & Levers 285/75/R16
    Ok Boys and Girls. New Dilemma.
    I need new lower control arms for the front end of my 2014 Tacoma off-road. And any suggestions would be greatly appreciated. I don’t want to spend $2000 lol. thank you
  2. Jan 21, 2025 at 8:33 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d go with the Mevotech over the Moog.
    I’ve used them on other vehicles, no problems yet.
  3. Jan 21, 2025 at 8:34 PM
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    OEM replacements are anywhere from $550-600 for the set. There are cheaper options on Amazon for around $200 a set. Dirt king sells some for around $1700 a set.
    dneal and MGMDesertTaco like this.
  4. Jan 21, 2025 at 8:38 PM
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    I need new lowers too. I hate the stock ones as I know they can be a weak point for severe abuse(I broke my OEM LCA years ago), beefy stock length is like $1600 and up. I wish someone made beefy stock ones that you can grease for like $750. When the time comes in the summer I’ll be pulling the trigger on OEM replacements. I can’t justify spending $2000 on stock length and not spending a bit more and just going full LT.
  5. Jan 21, 2025 at 8:46 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    LT is not "a bit more". It's about $5,000 more.
  6. Jan 21, 2025 at 9:49 PM
    skee
    skee Well-Known Member
    North Coast, CA
    2006 Tacoma TRD 4x4 Access Cab
    I have had TRQ brand LCAs installed for about 2000 miles. Still to early to tell reliability, but they mounted up just fine, ride smooth and alignment was no issue. And they were cheap, like really cheap under $200 for the pair. Figure if they don’t last I can replace them 2-3 more times for less than one pair of OEM. Depends on your needs, though.
    eherlihy and APaulcolyps68[OP] like this.
  7. Jan 21, 2025 at 10:53 PM
    APaulcolyps68
    Paul
    Called the Dealer and they said OEM are $460 each.
  8. Jan 21, 2025 at 10:55 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Whats wrong with yours?
  9. Jan 21, 2025 at 10:57 PM
    APaulcolyps68
    Paul
    Bushings and ball joints cracked
  10. Jan 21, 2025 at 11:17 PM
    APaulcolyps68
    Paul
    Freedom Off Road?? They have them for $400 a set.
    Dirt King is a little $$$$ ..
  11. Jan 22, 2025 at 3:24 AM
    UOFan
    UOFan Well-Known Member
    Bryan
    NC
    1994 Single Cab DLX, 2013 TRD Sport, 1999 Dodge 2500 360 V8
    5100 Lift + AAL
  12. Jan 22, 2025 at 5:27 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Just make a Toyota acct and buy online. You can get OE lcas for about 230-260 ea. and usually anything over $75 is free shipping.
    TRD10, wi_taco and APaulcolyps68[OP] like this.
  13. Jan 22, 2025 at 6:33 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The weak point on the cheaper LCAs are the ball joints. I got me some Dormans and the BJ’s were shot by 5K.
    A little sideline story on that - I replaced the Dorman BJ’s with Premium XL’s. They were about $15 each on rockauto. Five years later those BJ’s were holding up well. I come to find out Dorman’s ‘high’ end BJ’s are now those Premium XL’s, but I bet their LCA’s still come with no-name Chinese parts.
    Edit - the brand name is MAS, and now part of Dorman. Not too bad of a BJ. They gave me five years of service and I liked that they were sealed,
    https://static.dormanproducts.com/document/chs-steering-and-suspension_brochure.pdf
  14. Jan 22, 2025 at 6:38 PM
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    This! Don’t ever call the dealer and ask them the price…they like to accidentally jack up the prices. Shop around online!
  15. Jan 22, 2025 at 7:02 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If I were to buy them online with no shipping cost to pick up at my local dealer, they’d be roughly $700 out the door. Larger online dealers will cost a little less but shipping will usually cancel out a significant amount of that.
    kimosabe15 and APaulcolyps68[OP] like this.
  16. Jan 22, 2025 at 7:03 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    What did the worn out ball joints show as signs of wear? Busted boots and lost grease / corrosion or bad sounds / play etc?
    Flori-duh Taco likes this.
  17. Jan 22, 2025 at 7:18 PM
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    How do you make a Toyota account?
  18. Jan 22, 2025 at 8:12 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You don't really need an account, price compare the part numbers online:
    48069-04040 Left
    48068-04040 Right
    Not all online dealers are the same - I only usually buy online and pick up from my local dealer so you could check around on here, but McGeorge Toyota had a good reputation when I was on here more often 4-5 years ago.
    https://toyotaparts.ourismantoyotao...lower-control-arm-left-front-lower-4806904040
    https://toyotaparts.ourismantoyotao...ower-control-arm-right-front-lower-4806804040
    Depending on what shipping and tax look like it could come out around $600-$660 or so.
    TomHGZ[QUOTED] likes this.
  19. Jan 22, 2025 at 8:17 PM
    MGMDesertTaco
    Larry H Miller Toyota in Lemon Grove, CA or Norm Reeves Toyota in San Diego usually have the best prices. If you can wait for a major sale you'll save 15% or more. Otherwise, Dirt King lca's are a solid upgrade choice.
    I'm planning on getting those for my turd gen soon.
    TomHGZ likes this.
  20. Jan 22, 2025 at 8:18 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    That's about right, but I got mine for less. I paid $289.76ea + tax from one of our local dealers (West Coast Toyota) sometime last year. Bought online and then picked up in store.
    But dealers seem to increase prices annually. Same dealer is now selling them for $305.22 each. I still wouldn't do anything but OEM unless I only planned on owning the truck for a couple more years.
    Dalandser[QUOTED] likes this.
