Lower Gears and Speedometer Correction
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Canazes9, Jul 8, 2013.
  1. Jul 8, 2013 at 7:08 PM
    Canazes9
    Canazes9 [OP] Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    How difficult is it to correct speedometer/odometer for lower gears? Kicking around the idea of swapping in some 4.88 gears to run with 255/85 R16. I know that's lower than stock, should make it drive a little better, would like to have the speedometer/odometer read correctly.
    Thanks,
    David
  2. Jul 8, 2013 at 7:11 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
  3. Jul 8, 2013 at 7:19 PM
    Canazes9
    David
    Texas
  4. Jul 8, 2013 at 7:22 PM
    Supra TT
    Eric
    Indiana
    It's most accurate way, I don't know of any other way. Maybe the more knowledgeable 2nd gen owners do..
  5. Jul 8, 2013 at 7:37 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    I have 4.88 gears and used the hypertech inline speedometer calibrator. 30 minute install and my speedometer and odometer were dead even with a GPS.
  6. Jul 8, 2013 at 7:51 PM
    Canazes9
    David
    Texas
    Just looked it up - thanks! That looks a lot easier! Just hooks in to the OBDII port?
    David
  7. Jul 8, 2013 at 7:53 PM
    MrGrimm
    Dean
    Wisconsin
    See build page
    Yep, hooks into the ODB port and you hook that up to a computer. Enter in some numbers and bam, speedometer is correct.
  8. Jul 8, 2013 at 8:16 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Does the Hypertech have to remain installed on the OBD port or after the computer magic can it be removed?
  9. Jul 8, 2013 at 8:20 PM
    MrGrimm
    Dean
    Wisconsin
    See build page
    It does not stay installed into the ODB2 port. There is a wire than stays installed behind the speedometer. If you want to go back to stock, you just unplug that.
    Install Procedures
    I have an Ultra Gauge and I am still able to use it because it is always plugged into the OBD2 port.
  10. Jul 8, 2013 at 8:20 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Do this I need to.
  11. Jul 8, 2013 at 8:21 PM
    MrGrimm
    Dean
    Wisconsin
    See build page
    I got scored a hell of a deal and bought the Hypertech from a member on here for $30. Take a look around ebay and you might be able to snag one up for cheap.
