Lower oil level = better running?
Discussion in '4 Cylinder' started by DGXR, Jan 27, 2015.
  1. Jan 27, 2015 at 1:10 PM
    DGXR
    DGXR [OP] Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    2006 2.7L automatic access cab
    This thread is not about correct oil capacity or dipstick reading or any of the other hundreds of related topics.
    I've decided to switch to synthetic motor oil after using up my remaining dino oil supply -- I had 3.5qt plus one new 5qt jug. I decide to split the difference and see if I can get 2 oil changes out of 8.5qt. So on my last oil change I put in ~4.25qt with a new filter and after running it and checking for leaks, the oil level was 1/4 inch above the "low" dot on the dipstick. This is in the normal range, it's still purring like a kitten without any noises or problems, plus I drive it easy so I'm fine running it like this since it's in the normal range.
    So it has about 1qt less oil than all the previous oil changes and the engine seems to rev more easily and seems to make a bit more power at the same throttle settings. Plus the fuel mileage was a bit better on the last fillup, and I'm not doing any additional highway miles. (I drive slightly faster than grandpa, on the exact same routes at the exact same times every weekday.) Am I imagining that the engine is running better? Or is this plausible -- maybe less windage losses due to the lower oil level? Or something else?
  2. Jan 27, 2015 at 2:22 PM
    Indy
    Indy Master of all I survey.
    I'd attribute it to your butt dyno being off.
  3. Jan 27, 2015 at 2:30 PM
    rosie7562
    rosie7562 Member
    11 PreRunner SR5
    You will have less drag in the oil sump.
  4. Jan 27, 2015 at 4:43 PM
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    The only thing I could see is if the oil is shearing more quickly and losing viscosity. Either that or just heating up quicker.
    The uncalibrated butt Dino seems more plausible.
  5. Feb 1, 2015 at 9:19 AM
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    +1. And since our engines aren't very powerful in the first place, it's easier to notice small increases, kinda like turning your AC off.
    Since its above minimum, it should be fine But oil temp will be higher and oil life potentially reduced. Probably never enough to matter, but I may would change it a little earlier.
  6. Apr 29, 2016 at 10:11 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    You're dreaming!
  7. Mar 22, 2018 at 4:12 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    If you're above the LOW dot on the dipstick you're good. I use 5qt and I'm right on the MAX dot
  8. Mar 23, 2018 at 3:10 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    There’s no way a low oil level will make and engine run differently. The pickup tube is at the bottom of the oil pan so the same amount of oil is still flowing through all the components of the engine.
    05Taco4x4 likes this.
  9. Mar 23, 2018 at 3:11 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    that's one thread that didn't need to be revived
